My first Blanket Chest
jerome bias
>After lurking in the background for quite a while I thought that I would post a picture of my first case good piece that I have made. It is a simplified version of a blanket chest that is in MESDA�s collection, which is in Winston Salem NC.
The original has a drawer at the bottom, raised panels and beading on the stiles. After botching up a couple of the panels, I decided to skip that option and do some more research on making them and to keep it simple and to have flat panels. The drawer and the beading went the same way too. I figure that I can do a couple of different versions of the chest and each time get closer to the original.
I just finished the second iteration of the chest and it has raised panels, but I haven't gotten pictures made of it yet. It has come out fairly okay, but the fields of the panels are proud of the rails and stiles. I haven�t quite resolved that issue yet, which I need to soon. I am expecting a new panel raising plane and it will be here soon.
If you count a cordless drill as a hand tool, then I can truthfully say that I only used hand tools. I can also say that I really like the coloring that I get from walnut and garnet shellac. However, dealing with the defects that occur in walnut can be harrowing. I didn't expect to run into the sap tunnel that showed up in the top. Thankfully it worked in fine esthetically.
I'd also like to say thank you for all of the questions that y'all have asked and answered on the messageboard. They have made this project possible and I appreciate the help.
Thanks,
Jerome Bias
Mebane, NC
