Stanley 50 Cutters
Stanley 50 Cutters
Stanley 50 Cutters
Andrew Stonina
>Dear Woodworkers,
I recently acquired a Stanley 50. Unfortunately there are no cutters with it. I know from the type and literature that came with it that it is the one that had 17 cutters with it. I am wondering if anyone here has an extra set of these cutters or can tell me where to get a set? Thank you, for your help!
AndrewDS
Re: Stanley 50 Cutters
Ray Iles
Tony Sade (Charleston, WV)
>Try Ray Iles at:
http://www.oldtoolstore.co.uk/
ray@oldtools.idps.co.uk
I know he makes blades for some of the smaller comb. planes. Not sure about the 50 but he's worth a try as is Jim Reed who posts on most of the handtool forums. Not sure of his address, but he'll probably pop up in a minute or two.
HTH, Tony
Why our own...
Scott Burr in Ben Lomond, CA
>Jim Reed makes a set of Stanley 50 Cutters.
paul womack
>Given the (fully justified) cost of a new set of cutters, you can most likely get a whole #50 with all cutters for the same money, or cheaper if your luck is in.
Just an option.
BugBear
Funny you mention the 50 cutters
jim reed @ tallahassee
>as I am getting ready to make a production run for some lonely planes of mine. Is your plane an early model (no adjuster lever) or more recent model (with adjuster lever)?
Re: Funny you mention the 50 cutters
Andrew Stonina
>It has a cutter adjustment lever.
AndrewDS
My plan was for the adjuster-less
>since they are much easier (less expensive) to make. In use I find the adjustment lever is of only slight help. Easy to take off and use lever less blades.
Re: My plan was for the adjuster-less
Andrew Stonina
>Is one still able to use the blades from the earlier (lever-less) models in the newer models (with lever)?
Adaptability of the #50
>#50 blades of any vintage can work in a #50 plane of any vintage in my experience. If you have a later model with adjuster lever, just remove the screw that holds it to the frame. Put it in a safe place and use your non-adjuster blades. The trick with blades and the #50 is that the blades must be pretty short. For example, the #50 cannot use most #45 blades because they are too long and strike the handle.
Greg Brown
>I need a set of #50 cutters, preferably with the grooves in the back, but I can make it work without I guess I read the Jim Reed as a man who makes them, how do I contact him?....Greg Brown, Sydney Australia
Jack Guzman from Maine
>I have bought irons from Jim Reed. He sells a good product.---Jack
jimreed2160@yahoo.com
Limited set for users??? Opinions?
>Steel prices and heat treating costs are way up. To reduce costs, I am trying to come up with a limited set for users. Which cutters would the average user need? Any opinions?
Re: Limited set for users??? Opinions?
Ted Shuck, Centennial, CO
>The ones I use most in my Stanley 50 are 1/8", 1/4", and 5/16". I use the 1/8" cutter for bounding the field on raised panels, the 1/4" for drawer bottoms, and the 5/16" to make the groove for raised panels. The 5/16" is also the same size as the 48 irons. I like to use the Stanley 50 for narrower grooves, but when I need a wider groove I usually use my 45.
Regards,
Ted
No beads?
>Thanks for the input.
Re: No beads? Nope.
>I don't use the Stanley 50 for beading. I find woody beading planes much easier to use for that.
Regards,
Ted
But suppose someone doesn't have woodies
Bill Houghton, finally Spring? in Sebastopol, CA
>how would a No. 50 be if it were the only plane someone had available for beading? Would it work well then?
My No. 45 works right well for beading - I'd assume a No. 50 would as well.
Maybe offering it as two sets - the straight irons and the beading irons.
Re: But suppose someone doesn't have woodies
>Beads are surface decoration. Tearout is a significant disadvantage. rabbets and grooves are joinery. Tearout is much more easily tolerated. Wooden molding planes have mouths to minimize tearout, but ploughs and metal combination planes do not.
Alice Frampton, UK
>I use a Lewin, which is on a par with the #50, for beading all the time with no problems. Beading is one of the things I find combination planes are really good at, fwiw, to the extent of leaving all the woodies lying unused on the shelf.
Cheers, Alf
Re: tearout
>This is why I don't use my combination planes for beading. I get a nicer surface from the woody beading planes.
Ted
