I'm skeptical
Thom D
>Just so it isn't missed, Pics are in the thread below:
Well who can blame you? Maybe it is hard to believe that one can go straight from the 80 grit/shaping wheel to the buff, though you can see the same process performed in Tage Frid's half lap dovetailing video for FWW. Which presumably means everyone who went through his courses at RSD has seen it too. Inconvenient isn't it?
Anyway, occasionally I confuse even myself, so I went out to the shop for a minute to see if I was exaggerating. Freehanded a really nasty course white stone wire edge on a chisel, and then buffed it on the adjacent green wheel, not even a dab of the green stuff in much evidence and I didn't refresh it. 20 seconds later tested the end on a piece of pine and then maple, both of which it cut with ease. Then I shaved a big bloody patch on my arm, smooth as a baby's bottom, and I have a 19 day old baby in the house for comparison purposes. I then applied the barber's test to the edge. Wet your thumb nail and go in for a low angle catch, this is evidence you have properly honed an edge. Passed fine. Then wet a fingertip and go in for a catch, this test it failed, meaning it is not sharp enough to actually shave a face with and get a tip, but I am confident with a few more seconds on the wheel with fresh green compound it would probably pass. Most razor edges do not pass test 2, since typically in woodworking it was not the practice to strop an edge after wetting it on a fine Arkansas stone. That is the dividing line the barber's test identifies, when to move on to the strop, and when to move on to the face. I also ran my finger along the edge very carefully and it felt dead smooth to the touch, I didn't get cut, so it certainly isn't ragged in the least.
I would have no problem making money or giving a dovetailing demo with this edge just as it is.
Let's be clear, at 1800 rpm on an 8" wheel for ten seconds it's like dragging the edge along a scary sharp/diamond strop 628' long, 2 seconds is 125'. The average sharpening stroke I see with a jig is probably about 4" long so that is like 375-1800 passes. Most grinders are 3600 at 6" for 942'/ten seconds.
I'm not saying this is a perfect method, there isn't a perfect method. But it is perfectly fast, and relatively cheap. The whole rig including the motor is about the price of a shapton 8000.
Just what is there to be skeptical about?
