Truing up the edges of long boards?
Stephen Kirk in Quakertown PA
>OK, I have some 30-60" long 3/4" oak boards that have rough sawn edges. I don't have a power jointer, and not even a jointer plane. I do have a 16 inch jack (the LV LA). I've tried a couple of methods of truing up the edges (including attaching a straight edge to one side and then running that on the table saw, and trying to rout along a straight edge), but none worked particularly well. My only long straight edge is probably a bit questionable at 60" too. I tried using the jack plane to take the edge down, and it seems to have done a decent job. I ran a line using my (questionable) straight edge, and then planed down that. The board stands without much gap on my workbench.
I'm not going to glue up the boards, but I do not to make some long edge strips. Is there any better way of truing up that long of an edge, with a limited set of tools. I also usually cut a little oversize, and then fit the pieces during assembly.
