Poly finish question long
Matt in MO
>ALL:
I'm finishing up a walnut dining room table, first major project. I'm using a minwax fast drying poly. (clear satin).
I finished the bottom with a few coats and didn't mind the slight small pools of finish (even after a light sanding w/ 220 grit.) You can only see them at a certain angle.
Now, the top has the first coat on it. And it doesn't have pools of finish, but lines where I slightly overlapped my strokes. I applied the finish with a quality brush and VERY delicately. How can I get this finish to not have these lines/pools of finish? Will it all even out after three coats? Do I need to sand more? Are the coats to thick? Any help would be appreciated.
Matt
Re: Poly finish question long
thin it or heat it
bill tindall
>If there are brush markes it is because the finish set up before it flowed out level. The solution is less viscosity or slower cure time. I always thin varnish (paint thinner), while others heat it to the same effect.
R.J.Whelan (Eastern Sierra), CA
>Matt,
Here's another way to go:
Use Minwax Wipe-On Poly (#1 rated oil finish in FWW article several months back). There are three furniture makers (pro) where I live and we have all switched to this finish and we all love the results. We are all using the gloss, which isn�t very glossy � the satin is very dull and if you want any kind of sheen you�ll have to wax it after it fully cures (been there, done that, won�t do it again)
Even if you plane you�ll need to sand the whole piece to 320 before the first application.
Flood the surface with oil using a foam brush; keep going back over the piece and apply more finish to any area where the finish is absorbed and the surface looks dull. Wait about 15-20 minutes after the wood stops absorbing finish and wipe the whole piece dry � I use a piece of bath towel to start and finish with a Handy Wipe or piece of tee-shirt. Don�t worry about lint as you�re going to wipe this so much you�ll remove any lint.
Sand to 400-600 and apply another coat of oil. Little, or none, of this will soak in. I use a piece of Handy Wipe as an applicator on all but the first coat. When the surface starts to tack wipe dry as in Step 1.
Sand to 600 and apply a third coat of oil. When the surface starts to tack wipe dry as in Step 1 and 2.
Rub out the third cured coat with steel wool, bronze wool or Scotchbrite and apply a fourth coat of oil and wipe dry almost immediately.
Rub out and oil additional coats as desired.
One of my furniture building competitors just finished a walnut trestle table as describe above and it looked great. I finished a cherry and ebony Mission dining table just a few days ago and it came out fantastic. I have probably used almost every finishing technique (not every brand though) there is, and I like the results with this finish as much as anything I�ve ever used and better than most of them.
Good luck with your table � rj
Paul M. in San Diego
>Hi Matt,
I agree with Bill. Thinning out the finish is the best way to eliminate these marks.
The first 2 coats can use a little leveling, then use a thin coat for the top-level to make sure it floats out properly.
I would question your usage of satin finish for all 3 coats. I always use gloss for every coat, and only use satin for the top coat if desired. Using multiple coats of satin makes the finish look rather opaque rather than clear with a satin sheen to avoid the glossy look. I did some baseboard molding on my house with 3 coats of satin, and it turned out looking very plasticy. I've been wanting to redo that molding ever since, as it still bothers me.
Matt in MO
>Everyone,
Thanks for the advice. As I'm moving cross country in less than a week, I stuck it out with full strength poly for speed. After the third coat, it leveled out. I'll post pics when I finish moving.
For future reference, what ratio would you suggest for mixing? I presume any type mineral spirit would suffice.
Matt
