chairmakers brace
chairmakers brace
chairmakers brace
McKay from Utah
>I would like to make my own chair brace, but I do not know how the bits were chucked. Does anyone know how it was done? Where would I look? Thanks in advance for any advice
Re: chairmakers brace
Keith from Tennessee
>If you want one brace and several bits mounted in pods, the bits are wedged in the pod kind of the way a chisel tang is set. The pod is a taper lock in the brace. If you go the one brace for each size bit route, the bit is just wedged in the same as a pod. I do 18th century living history events and I patterned mine after the Dominy's brace pattern. The original bits had more of a flat tang. Email me if you want pics. Hope this helps.
We all want pictures, Keith
Adam Cherubini
second that
john jesseph
Re: We all want pictures, Keith
>I'll need to read how to post pics. Will head out to the shop with the camera.
Brace pics
>This is a chair makers brace with the mounted spoon bit. Below are new spoon bits with the flat tang. All my chair braces have this type and wooden wedges are used to secure any loose fitting bits.
Brace pics 2
>This is my copy of the Dominy's pod brace. I mounted modern spoon bits in a wooden pod that fits the brace with a tapered fit.
Pic 2 again
Steve Kubien
Re: Pic 2 again
Steve Kubien
>Now that is just plain sweet! Thanks for sharing.
Steve Kubien
That's nice!
Scott Burr in Ben Lomond, CA
>Them sum darn perdy bit stocks ya'all got there. Still I can't help with your original question...
WOW!!
Wiley Horne
>Keith,
This is really wonderful work. Thank you for sharing it. Did you make the spoons yourself, or were you able to find a set? How critical was it to center the bits on the brace's axis?
Wiley
Re: WOW!!
>Thanks Wiley,
The bits are modern bits that I found several years ago. The bit has to be on axis as much as possible. The bit will run true itself but will make the brace wobble if its not on center. Not a big problem if its off a little.
Keith
Re: That's nice!
>HI Scott,
I posted the pics because Mckay had a question on how the bits are mounted. Not sure why the pic is out of focus. Still working on resizing photos for upload.
Keith
