A question of plane blade bevel angles *LINK*
Ian Smith (Sydney Australia)
>First of all. Please allow me to introduce myself. My name is Ian Smith and I live in Sydney Australia. The link below takes you to my user profile which tells you a little bit about me.
I have been lurking here for a while and have only just recently started making a few comments. This is the first thread that I have initiated.
My question relates to bevel angles for my low angle block plane and my low angle jack plane. I recently purchased spare blades for both of these planes and I want to hone/grind these to a higher angle than the standard 25 degree bevel so that I have the option of a higher cutting angle when planing some of our Aussie hardwoods. I am assuming that I can leave the standard bevel at 25 degrees and simply achieve the higher angle via a micro bevel. Is this the case or do I need to grind the entire bevel to a higher angle before honing a micro bevel?
Thanks in advance.
Regards,
Ian.
My Profile
