The Veritas Skew Jig *LINK*
Derek Cohen (in Perth Australia)
>The Veritas Skew Angle Jig has just been released. This is one of two accessories for the Veritas Honing Guide Mk II. The other � not dealt with here � is a unit with a cambered wheel for honing cambered or radiused blades.
The basic Mk II was designed to focus specifically on straight bevels. Before the skew jig was developed, I outlined a strategy to create templates for honing skew blades, link below.
Several months ago I was sent a pre-production version of the jig by Lee Valley for evaluation and feedback. With the release of the production model I was sent this version as well, and I am now in a position to offer my observations on the final form. What I plan to do is illustrate and demonstrate what the skew jig does. The aim is to help you decide whether this jig is going to be useful in your own workshop.
Of course, the skew jig is only going to interest those who (a) have skew blades they wish to sharpen, and (b) already use, or plane to use, the Veritas Honing Guide Mk II.
It is quite amazing how many tools-with-skew-blades are in my workshop. Here are a few for inspection.
There are skew chisels (for dovetails), a Lie-Nielsen #98/99 side rabbet set, a Stanley #79 side rabbet plane, a Stanley #46 combination plane plus a set of skew blades, a shopmade dovetail plane, an ECE skew filletster, and a Stanley #140 skew block plane.
In my experimentation with the Skew Jig I managed to cover several different blade types, such as those above, and will detail these below.
Overall, I think that the concept of the skew jig is terrific � makes my templates appear hard work! It is straightforward to grasp the principals of its design. I think that we need to start with this. The following instructions and illustrations are taken from the Lee Valley website (http://www.leevalley.com/wood/page.aspx?c=2&p=53974&cat=1,43072,43078&ap=1). Pictures have been added of setting angles on commonly used blades.
The jig attaches to the guide using the same dovetail feature along the front of the blade carrier as the standard registration jig. It is used with the blade carrier set to the 2 (yellow) standard-angle configuration.
The jig is designed to hone bevel angles of 20�, 25�, 30� and 35�, and skew angles from 10� to 45� in 5� increments. Skew angles for 18�, 22� and 28� are also included, as these are common angles for skew plane blades.
The fence is reversible to accommodate left and right skews. Simply flip it over end for end to orient the blade stop left or right, as needed.
Setting up for the #98/99 LN or Stanley Side Rabbet Planes
Step 1: Set the Bevel Angle
Place the fence in the appropriate groove for the bevel angle you are honing. The fence shown is set for a 25� bevel angle. In the following picture, the jig is being used to determine the skew angle. This is 30�.
Step 2: Setting the Skew Angle
Having established the skew angle, slide the fence so that the blade stop is tangent to the appropriate skew angle line. If the skew angle is known, go directly to this step.
Step 3: Centre the Blade �
� and you are ready to go.
Setting up for the Stanley #79 Side Rabbet Plane
The blades for the Stanley #79 Side Rabbet Plane have a 30 degree skew angle and should be honed with a bevel of 25 degrees.
These blades are too short to fit the Veritas skew jig set at the desired bevel angle.
However they will fit if set for a 35 degree bevel angle.
Now, if the Blade Carrier is locked on the GREEN setting, the bevel will be honed at approx. 25 degrees (the #79 blade is small and I could not be completely sure that my readings were accurate).
Setting up for the Stanley #46 Combination Plane
The Stanley #46 Combination plane: blades have a 20 degree skew angle and the bevels are 25 degrees.
This was straight forward to set up and hone.
The Stanley (and LN) #140 Skew Block Plane
My Stanley #140 skew block plane has the unusual skew angle of 21 degrees (and a bevel of 20 degrees). If I used a 20 degree skew angle, the blade would be canted in the mouth. So it required a custom setting.
Since my skew angle was already established, the bevel angle was set by squaring the bevel edge with the fence. Note that the example below is set up for 25 degrees.
Skew Chisels
I have �� wide Crown skew chisels (left and right): These have a skew angle of 40 degrees and a bevel of 25 degrees.
If the blade enters from the direct rear of the Honing Guide, then the maximum width blade it can fit (with the skew) is ��. This is also going to lead to a poor centering of the bevel for honing.
Instead, the blade should enter from the side of the Honing Guide.
Conclusions
The Veritas Skew Jig essentially delivers what it sets out to do, that is, establish the honing angle for skew blades in association with the Veritas Honing Guide Mk II. It does this with the minimum of complexity and is quick in execution.
There is no difficulty for blades either with skew angles that are known (but not honed), or with blades with non-standard but established skew angles. For those unhoned blades with non-standard skew angles, the bevel will first have to be established, and in these situations I suggest you refer to my directions for creating templates.
Derek Cohen
Perth, Australia
April 2006
Advanced Angles on the Lee Valley Honing Guide Mk
Re: The Veritas Skew Jig *LINK*
#2Re: The Veritas Skew Jig
Wendell @ Murphy, TX
>Any idea what plane iron the 28, 22, & 18 degree marks were made for? The instruction sheet calls them out but does not explicit say which plane the marks are meant for. Until I read you post, I had assumed they were meant for the #46, #79, #140 and whatever other Stanley planes have skewed blades.
Wendell
#3Re: The Veritas Skew Jig
Rob Lee
>Hi Wendell -
Mostly for Stanleys, and copies thereof...
Really - it'd dead easy to set the jig without using the scales... the important thing is always to preserve the geometry you have. Just pivot the chisel against the fence until the blade edge and fence are parallel...
Cheers -
Rob
#4Re: The Veritas Skew Jig
>I have some #46 blades that don't have a constitent skew angle between the lot of them. I was really looking for the list matching plane # to angle so I would know what I was suppose to use in case the blade was messed up.
Wendell
#5Re: The Veritas Skew Jig *LINK*
Ted Shuck, Centennial, CO
>Derek Cohen posted a very good response to this question about getting the skew angle right for any given plane. I have looked up his response and provided a link here...
Regards,
Ted
http://woodcentral.com.ldh0138.uslec.net/cgi-bin/a
#6Re: The Veritas Skew Jig
Handrubbed
>Derek, very thorough, as usual. How did you deal with the undesired "skew" that many have posted about with this jig? What I am referring to is the tendency for the Mark II to not be able to hold narrow irons and chisels securely. There have been many suggestions, but as far as I know, no fixes other than glueing sandpaper to the jaws of the blade clamp. Perhaps that has been addressed with the new fixture.
#7Re: The Veritas Skew Jig
This does come up every now-and-then. Indeed. And to the best of my knowledge, most - if not all - occasions it has been found that the "problem" lies with the chisel/blade. That is, there is a high spot on the back/front of these on which it will pivot. I see this issue as the "weakness" of any jig that relies on downforce to secure a blade. Those that use sideforce avoid this (but then may run into other "problems").
In my original observations, when the LV Honing Guide Mk II was launched, I noted difficulties with narrow chisels. This was discovered to be due to the angle at which the clamp met a tapered chisel/blade back (resulting in insecure/out-of-square contact). LV modified this prior to release (they changed the angle of the clamp), and my re-testing (on the problem chisels) found a very significant improvement in this area.
#8Re: The Veritas Skew Jig
Dave Thompson
>Wow Derek, that was quick. I just read Rob's note a week or so ago announcing this on another forum. When I read Rob's note earlier and saw the link at LV, I think I finally got the gumption I needed to get the angle corrected on my whacked out old #98 and #140.
Nice review btw.
#9Re: The Veritas Skew Jig
Ian Smith
>"Any idea what plane iron the 28, 22, & 18 degree marks were made for?"
The skew on the Lie-Nielsen #140 is 18 degrees, not sure about the 28 and 22 degree marks though.
Regards,
Ian Smith
Sydney Australia
#10Re: The Veritas Skew Jig
paul womack
I used to have all sorts of problem with many types of jig not holding the blades firmly enough.
The common factor was (of course) ... me.
I was relying too much on the jig holding the tool, instead of the jig providing guidance to me holding the tool.
Once I relied on the jig to guide me into the correct motions (and didn't fight it, or rely on it to force me in the correct motions), all my blade holding problems went away.
To exemplify, I sharpen skew blades with a Marples #7418.
Alf's scan of the #7418 "manual"
It does not hold the blade very tightly at all... (but is plain enough to be rather versatile)
BugBear
#11Nice one Derek
Ian Smith (Sydney Australia)
>Nice review Derek. You inspired me to place an order for one. Rob should put you on commission.
Regards,
Ian.
#12Re: Nice one Derek
Don't even joke about that Rob. That is a bad road to go down ... :(
I just attempt to portray the tools as I find them. The "trouble" is that LV always seem to have such desirable stuff. :) It sells itself. If other manufacturers want to send me the stuff for critique (which is all LV tend to do) or to review, I would format the write-up in exactly the same manner. It is just a hobby.
#13Re: Nice one Derek
>"Don't even joke about that...."
No worries Derek. Point taken. You're right about the Lee Valley stuff being desirable. Them and Lie-Nielsen seem to be receiving my entire tool budget of late.
Regards,
Ian.
