bit and brace drilling - end screw clogging
timlangford
>I recently was playing around with some new (old) bits for my brace. They cut nice a clean but the end screw quickly clogs with material and won't pull the bit deeper. I was using them on black walnut. Is there a trick to keeping the screw clear of material or if not, what's a good way to quickly clean the material off the screw. The waste material was wound around the screw pretty tight and didn't want to peel away with my thumb nail. Thanks
Re: bit and brace drilling - end screw clogging
mikew
>Hi Tim,
Is the lead screw the fine one? I find I need to use the medium or coarse screw on softer woods, like Walnut.
Even some of the harder woods I find the fine screw will clog. Constant downward pressure helps sometimes. Letting up can cause it to spin, and once that happens it can be difficult to get it pulling in again.
I have had success removing the bit, cleaning the screw and then applying more pressure to get it going again.
Hope this helped, Mike
Adam Cherubini, NJ
>The problem is not with the lead screw. The clogged lead screw is the symptom of a dull bit. So get out your auger bit file and refine the cutting edges. If you do it correctly, you'll find your bit will eat thru the wood with ease.
Adam
Re: sharpening auger bits
>I have a number of bits that could use sharpening. I actually have an auger bit file. All I need is enough knowledge to give me the confidence to tackle the job. Whenever I read about auger bit sharpening, the info is pretty basic. Is it really that easy? Perhaps you would have some definitve pointers, and an article would be nice.
Jack Guzman from Maine
>I haven't tackled that particular job yet either.I have the file,just haven't tried to sharpen a bit with it yet.I guess if I used my brace more I'd find the need...or...if I sharpened my bits maybe I'd use the brace more.---Jack
Yes it really is that simple
Bill Houghton, might be Spring in Sebastopol, CA
>and sharpening is amazingly quick, IF you have an auger bit file, which has the two advantages of being small enough and having safe edges so you don't file where you don't want to.
arw01
>I have also read on the old tools list that the screw threads need to be nice and clean and sharp. This keeps wood from hanging up in there.
ALSO when I drilled all the mortise holes for my bench, I found that every 5 or 6 cranks a half crank back cut the number of fouled screws considerebly.
I will have to work at getting my bits sharper than, although it is easy, it still takes some time to fix old bits.
Alan
>Assuming you still get some clogging after following all the fine advise you're already received, you can remove it with a brass wire brush. Don't use a steel wire brush, because that will prematurely dull all the edges you want to keep sharp. To make cleaning it easier, a little beeswax, parafin or camellia oil can be applied to the screw before you start boring.
You got it Bill!
Scott Burr rockin' Ben Lomond, CA
>It's a breeze to sharpen auger bits. Lee's book on sharpening explanes it all and it simple.
Now if I could get the balls to sharpen my saws...
Sharpening auger bits - the original manual
Andrew F in Australia
>Linked below is Irwin's manual detailing lots of information about these beasties. Sharpening (from memory) gets a special gong.
Cheers,
Andrew
Link to Irwin Auger Bit manual in above msg
Re: Sharpening auger bits - the original manual *LINK*
arw01
>The geocities site is over it's bandwidth.. I picked up a copy of the pDF from the way back machine..
Irwin PDF from way back machine
Thanks Alan, much appreciated
