name that 18th century molding?
bill tindall
>Does the double humped molding that was applied to face (front edge) of 18th century cabinetry frames have a name?
There will be a follow up question once I know what to call it and that would be how to cut the male and female parts where the horizontal pieces join into the vertical pieces- arrow point into vee. If it was flat I would cut the point and scribe the vee. But it isn't and I don't think I can get an accurate scribe on the humps and valleys.
Re: name that 18th century molding?
egg and dart?
Larry Williams
no
bill tindall
>It is side by side beads running parallel to the case edges: flat-bead-flat(or near flat)-bead-flat. About 1/4 thick and often not quite as wide as the case edge. The opposite of flutes. Purpose is to cover up drawer divider dovetails.
Beads 'n Reeds
Dave Thompson
>Multiple beads are reeds, made with a reeding plane.
...just happen to have my chapin-stephens catalog by my side at the moment.
enjoy,
Dave
double arch mold
Adam Cherubini
>These are usually scratched, thus no plane and no real name. This is the name the museum types use. The double arch mold is characteristic of early 18th c furniture, typically in the william and mary style.
Adam
Fitting the molding
Warren in Lancaster, PA
>I think that if you try to make all your miters in the molding before gluing you are asking for trouble; its hard to fit so many joints at once and also have it fit on the carcass. Here is what I would do.
Miter just the ends of the vertical strips and glue them on. You might nail them between beads also. Then put the point on one end of the divider molding and lay it over the edge of the vertical strip and mark the molding at the high points of the bead. Chop with a chisel about 1/16" away from your mark, relieve on the waste side and chop some more until you have a vee cut in. Then I would pare the vee to fit the divider point. The point of the vee is at the center of the molding , between beads. Then set the newly cut joint in place and mark the other end, first the divider strip and then the side strip.
This way you are only doing one joint at a time and you are always working off of the pieces aready in place.
man with the plan
bill tindall
>Ah, that should work. Think I should practice a few first? In my case a few dozen..........
