North Bros/Yankee handrill
Luke Herzberg
>I don't own much in the way of eggbeaters, in fact just picked up my second one at a yard sale this weekend. It's a 1530a with all the ratcheting gizmo. Firstly a question: The drill had some years of gunk accumulation so the ratchet didn't work freely. I took it apart, de-gunked and reassembled and everything was backwards...RH was LH, double LH, etc. I flipped the ratchet upside down and it works correctly now, but it wasn't assembled that way before I tore it apart. For those with these things, the text on the ratchet is upside down when the drill is vertical with chuck down...correct way?
Secondly, this is quite the clever little device when you tear it apart and see what is going on. The only other eggbeater I have is one gear, no ratchet, lock or otherwise. My biggest complaint was just trying to hold the darn thing while tightening or loosening the chuck, which the lock addresses nicely. More cool tools!
- Luke
Re: North Bros/Yankee handrill
>That's the way the text runs on both of my 1530A drills, as well as on the honking big breast drill with the same ratchet. Sounds like some other part got upside down.
