Superior Utility of Short Planes
bill tindall
>Not to let a good argument wither.....It is time to install molding on this massive Chester Co chest (what I have been incorrectly calling a PA Dutch chest). I want to get the case frame in shape for finish before installing moldings as it is hard to sand/scrape or plane the intersection where things lap, in this case where a complex molding is applied to chest top and bottom. The chest side is a frame and panel and here I am smoothing the panel frame joints with a "Nibbler" (I nibble at things with planes and chisels). My M&T technique is such that some nibbling is required to get the frame joint flat, or at least flat over the 3-4" span that I worry about. Well, it wasn't too bad as that is amount of shavings to level it.
The plane I dashed together for the task. It is Ipe, very stable, abrasion resistant and heavy. (It is also a pain to work with and I may go back to maple) It's bedded at 50 degrees, traditional for a joint nibbling plane. Its currently 8"long and will soon be 7" long as its excessive length bridges over hollows which I find annoying, and tedious to deal with.
The single board panel is partially prefinished.
Re: Superior Utility of Short Planes
Dave Thompson
>Pretty nice Bill for a plane just "dashed" together. So what are the headlight and tighlights on there? is that a holly dowel rod?
How are you doing the moldings? H&R's or routah/shaper?
they are gone...
bill tindall
>the "headlights" are the alignment dowels to assemble. I cut plane as long as I could to try it. Too long, so it is now 7" and the headlights are gone. Works better at 7" for my needs. If you were to see it up close you would see that it is pretty crude. Sawed to shape with band saw and the corners knocked off with a file. I'll get around to shaping it someday, along with a few other I'll get too's someday.
I have decided to bite bullet and obtain a means of making ogees of size and shape as needed. It is a very common molding on old stuff so making a custom shaper cutter every time I make something is not very practical. I have borrowed some hollows and almost have this molding right. I will order some new hollows as I am fed up with rehab work. I'll make the rounds I need as I can turn the round on the lathe any diameter needed, and grinding iron to fit is easy. I have made one round and it was but slightly harder than this plane. It's fairly ugly but cut well. I haven't figured a way to easily make hollows so I will buy them.
Bill, How the heck do you make rounds
Don in Northern Arizona
>on a lathe, without having to make a hollow on the plane body to fit it. This is probably extremely obvious, but I a baffled.
Don
Re: they are gone...
Dan Donaldson
>Make the rounds, then use the round to make the hollow ;-)
Ah, the dim bulb brightens. 8-)
Re: Bill, How the heck do you make rounds
>Not sure how he does it, but I am picturing cutting the turned dowel in half and using it for the bottom of the plane.
depends on radius
bill tindall
>For larger radi I just mount the plane off center and turn away. Everything is lined up perfect. For small radi where the plane heigth would not accomodate this approach I turn a dowel , split and glue to plane bottom.
This isn't 18 century construction, as that is way beyond my means or patience. But by fabricating pieces, angles, cutouts , curves and the like with machines it all goes quickly enough to not be an impediment to geting a tool to do the job. Blanks for irons get made when we send other stuff for heat treating.
I am in awe of the people on this forum that recreate old tools but I don't have the skill or patience for it.
Re: Thats an Atlas right?
John in NM
>I've got a Craftsman version of one of those.
John
