Scrub pics for Todd O. et al.
John in NM
>Took a few more yesterday, here's the best of em. First is just an upper view with the blade in place. The donor of the blade and lever cap was a stanley handyman or something like that, cheaper than the Bailey's but this one had a kinda cool checkered lever cap that I wanted to re-use.
Re: Scrub pics for Todd O. et al.
Same view without the blade
John in NM
Closer view of the throat
John in NM
And the mouth
John in NM
>with a bit of blade showing. The only improvement I plan to make one day is a better blade. The old one is ok, but not even close to the quality of a Hock O-1 or A-2.
Thanks John, and questions
>John,
Tell me, how do have that lever cap screw fixed into the throat so it won't pull out? T-nut perhaps?
I like that lever cap. Can say as I've seen one quite like it before. Looks to be off of a Transitional, but I don't recall seeing one with Stanley in it before.
What's the striker button? Cocobolo?
So, how about a few "action shots eh? I can't speak for the rest, but I like to see shavings with homebuilt planes, they go together like peanut butter and jelly.
Thanks for getting back to us so quickly, very nice plane, and it is really nice to see a bit more of the details.
Watch out Steve K. ;~)
Todd O.
Re: Answers
John in NM
>Hi Todd,
The screw is just a big brass wood screw, #12 I think. I drilled a pretty tight hole and pre-threaded it with a steel screw to keep the brass from breaking (little wax helps too). Striking button is ebony.
Thanks for the compliments, I'll work on the action pics (almost got the camera all figured out).
John
You thinking about making one?
Ernie Miller
>I think I may have a lever cap like that one. I know I have a drawer full of the plane checkered ones. I'll send you two if you send one back attached to a plane. I'll even throw ing some blades to make it easy on you.
