Here's a scub plane I made....
John in NM
>a couple years ago (just got a digital camera), after dropping the 5 1/4 jack that I had been using up to that point. Yep, it broke in two, leaving me with a blade, lever cap, and a bunch of parts I've yet to use for anything. Made the plane out of scraps of cherry from work, along the Cecil Pierce lines of holding the blade in (ie: wood screw and the lever cap). Works quite well, even if the cherry is just a touch light and soft for this type of plane.
John
Re: Here's a scub plane I made....
Dave Thompson
>Very nice John. In fact, it actually looks too nice to be just called a scrub plane.
Your post is inspiring. A project mulling over in my brain has been to make an ultimate smoother starting from transitional parts which aren't necessarily the best or cheapest starting point. Maybe I'll start with parts from an iron plane...
Regardless, thanks for the post...
Dave
Kind of neat
Bill Houghton, raining again...in Sebastopol, CA
>A pretty tool, very shapely. I agree that it seems awful nice for a scrub plane, but on the other hand, that plane type seems like a good first plane to make, since the requirements for the mouth aren't super precise.
Tom in Tipp
>John,
I like that plane. I'm thinking about making something like this later this summer. I might contact you about this project, if you don't mind.
Thanks,
Tom
Re: Sure, anytime
John in NM
Re: Very true about the mouth...
John in NM
>It was surprisingly easy to make. The scrub is also a good one to do with a recycled lever cap, as fine adjustments aren't really necessary. For a smoother, I think I'd want to do a screw lever cap like on an infill, so hammer adjustment would work well.
Steve Kubien
Steve Kubien
>Nicely done John. I am in the middle of re-doing my homemade scrub. On the original I made it so the wedge was at way to steep an angle (think 20 -25 degrees) and I made the wedge out of some REALLY hard dogwood. I am taking a little more care this time out, aiming for 10-12 degrees on the wedge and going with something softer as well. Mine will be a beech core, with cherry sides sandwiched like one of Steve Knights (not nearly as pretty though). Unfortunately I need this new scrub to level some planks for a new chair seat (really not happy with the original).
BTW, I think cherry is fine for a scrub. Yup, it will get dinged up and the sole may get some gouges but, hey (!), it's just a scrub, right?
Cheers,
Steve Kubien
Derek Cohen (in Perth Australia)
>John
Beautiful design and very nice execution. Too pretty to waste on a scrub!
Never seem a...
Scott Burr raining again in Ben Lomond,CA
>Razee styled scrub plane before. It look real nice John. A job well done!
Cecil would be Proud
Todd O. Cronkhite Maine Native now in Jax Fl.
>Got any action pics?
Excellent job ol' boy, Excellent Indeed.
Todd O.
Re: Thanks Todd...
John in NM
>No action pics yet, perhaps once Jean gets the hang of the camera (or the plane, she uses the jack and smoother, likes it better than sanding).
BTW, what part of Maine are you a native of? I lived a few years up in Aroostook county, then went to high school in Orono. Miss everything but the blackflies and that last spring blizzard.
John
Re: Thank you all for viewing, and the kind words
John in NM
Re: Thanks Todd...
>John,
I'm from East Livermore, which is a bit of a spur off of Livermore Falls proper. The closet biggest major city would be the Lewiston-Auburn area, a.k.a. L-A. I'm also not to far from 'Gusta.
I never made it up to The County except for a 4th grade field trip to Ft. Kent.
While growing up I dreamed of being sort of a hobo and working my way around the U.S., but now I'd settle for doing that strickly in Maine. Had I been introduced to Eric Sloane while still in school I just might of done that. Coarse, I'd of had to have taken drawing/art classes as I can't draw worth a tinkers-durn naturally.
Brother, brother you've got to take the good with the bad, the blackflies don't last too long, and the snow melts. Sure beats the heat, posinous critter, man-eating critters, and the hurricanes of Florida in my opinion.
T.O.
More Pics requested
>John,
When you can do post more pics of this razee scrub. I'd be interested in see the throat area and the mouth. That tote sure looks LNish to me--goood job. how do have that mounted? Sitting in a mortise, or simply screwed up thru the sole?
T.O.
Re: Tote is in a mortise...
John in NM
>which is undercut at the back end, with a kinda half-dovetail on the end of the tenon. I seem to remember thinking of pinning it too, but now I can't remember why I didn't. Just used a bit of hide glue to help it out.
I'm heading up to Colorado tomorrow, but I'll see if I can snap a few pics later this week.
John
Nice scrub John!
Raymond in Trenton, NJ
>That sure is a handsome looking plane. I'm a bit curious about how long it is. Thanks for sharing and have fun using it.
Raymond
Re: here's another...
paul womack
>But I cheated a bit;
sorta' making a Scrub plane
BugBear
Re: 13.5" long...
John in NM
>Took some more pictures for Todd this morning, got to reboot the 'puter to get it to recognize the camera (ahhh, technology!), so I'll post a couple more tomorrow or so.
John
Thanks and looking forward to the add'l pics
