How my #5 1/2 was pressed into service
Jim Reed @ Tallahassee
>I am building some bookshelves (hack carpentry using 2x4s & plywood). The base is a rectangle of 2x4s. I noticed on my prototype that the base rocked on the worktable because the 2x4 had a slight bow. I clamped it down, got out the #5 1/2 (first plane I found that was larger than a #4) and made some shavings. Beautiful fit. Now back to electron burning.
Re: How my #5 1/2 was pressed into service
You're a sick man Jim Reed! ;~)
T.O.
#4 also
>Then I used to my #4 to shave down the plywood back to make it even.
