Help - Need Auger bit sharpening primer
Michael Stadulis, in Gloucester County, NJ
>Can anyone help me with a good link? No luck finding one yet.
Thanks for the help,
Mike
Mike
Re: Help - Need Auger bit sharpening primer
arw01
>Leonard lee's book is what I used. Bought the file from LV too. Although my biggest issue is with the lead screw clogging with wood so it stops pulling the spurs and ramps into the wood.
Alan
No link but
Ed Mulligan, Cape Cod
>Leonard Lee's book on sharpening has a page on auger bits.
Ed
Joe Rogers, Northern Virginia
>Dang...wish I knew how to post a link. Tom Price of the Old Tools List has a fix for this problem.
http://homepage.mac.com/galoot_9/auger_screw.html
Oh Well...copy and paste:-)JR
Re: Help - Need Auger bit sharpening primer *LINK*
L. Hanson
>Don't know how much help this is for you, but here is Irwin's answer:
"Question and Answer:
Q: How do I resharpen Irwin auger bits?
A: First never sharpen the outside edges of the bit that cut--the spur and side lip. There are three edges you may have to sharpen--the spur, cutter and side lip. Your bit may not have a spur. The spur is a thin piece of metal that sticks up parallel with the screw point above the cutter. To sharpen it hold the bit by the shank or twist against a work bench. Using a flat file, sharpen on the front (as you view the cutting edge) and top inside edge of the spur. Never sharpen the outside. To sharpen the cutter and side lip, hold the bit upside down with the screw point sticking into a piece of wood. This gives you a clear view and access to the underside of the cutter and inside of the side lip. Using a small triangular or square file, sharpen the underside of the cutter and inside the side lip."
HTH
Leif
JimG
>Another book with a couple of pages (and illustrations) is "Hand Tools - Their ways and workings" by Aldren Watson. Lots of other good information in there, too. Also a note on clogged screws.
HTH
Ben Franklin has the answer
Bill Houghton, raining and raining, Sebastopol, CA
>In my experience, any older book that includes a discussion of hand tools discusses sharpening auger bits. The main things are a) don't sharpen the bottom of the cutting edge (horizontal part that actually cuts), and b) don't sharpen the outside of the spurs.
Official auger bit files, such as Joel sells, really help: right size, and the safe edge on one end and safe face on the other keep you from filing where you didn't intend to file.
Thanks Gang!!
>Hey, Thanks very much for the replies. If anyone is looking for any bits, there is a used tool place by my office that sells used bits by the boxload and very inexpensively.
-Mike
Adam Cherubini
>I remember reading this years and years ago. I too have filed my lead screws until they are sharp. Having it clean does make some sense, but I've been long of the mind that the reason the lead screw clogs is because the cutters aren't sharp enough to allow it to advance fast enough. So my advice is soak your bit in kerosene for three weeks, then tooth brush it clean, then if you find the lead screw clogs, turn your attention to the cutters, spurs, etc.
Also, I've come across bits that cannt be sharpened. The cutter have been filed back so far, that any edge would have too high a bevel to allow the lead screw to function correctly.
FYI- Michael I live about 40 minutes North of you. Drop me an e-mail if you are having questions like these and we can get together. This is one of those things where those of us that have done this can show you faster than explain it.
Adam
arw01
>Great link, will have to order myself a set of needle files and give that a try!
Alan
Luke Herzberg
>One other thing to add...instead of an auger bit file, you can make your own by supergluing sandpaper to little bits of wood. Somebody posted that here once, but I can't remember who. I just did some bit sharpening for the first time last week and it's amazing what a difference you can't make going from dull to kinda sharp, and not even "razor" sharp like a chisel.
- Luke
dave caudill
>Michael I seem to remmeber an article in Fine Woodwokring a year or two back. I'll take a look and see if I can come up with something. It may have only been twist bits but I'll see if I can confirm that.
Dave
