Fore planes
Edward J
>Finally got my "dream workbench" built. Top consists of two 6'x 12 1/2" maple block tops salvaged from old baker's bread tables. The "chasis" consists of 11/2'x 31/4" red oak salvaged from pallets. I have a slight crown on my top where the two slabs are joined. To the best of my limited woodworking knowledge, the only way to remove this crown is to use a jointer or fore plane.
Easier said than done.
Seems Stanley of Canada doesn't recognize that 18" fore planes and 22"jointer planes are alive and duly presented on Stanley's website. A special order with applicable fees and costs are necesary to get the plane. I found an 18" foreplane at an antique place for $25 CDN $. I'm presuming it's an old Record #6, has the "6" cast on the sole near the tail, has 6 and A cast on the frog, and 6 and B stamped on the lever cap. Made a new knob for it, lapped the sole with 90 grit silcone oxide on a sheet of glass, and tweaked the handle a bit, but what I'm concerned about is the amount of throat showing with the blade set for light shavings.
Even with the frog pushed up all the way, the throat has about 1/8" showing, which I feel is too wide for light shavings needed to true up my top. The iron, or blade, measuring 23/8" is not orignal, stamped with "made in Gemany". Don't want to enlarge the holes on the frog so I can push the frog further up, and don't know about shimming the blade a bit to close up the gap in the throat. Any suggetions?
