REAL MILK PAINT
Saw blade steel
Saw blade steel
Saw blade steel
wayne
>I want to make a couple of Back saws an am looking for small amounts of blade steel. I have used sheetrock taping knives with good results but would like other options.
Re: Saw blade steel
Re: Saw blade steel *LINK*
David Barnett - SW Florida
>From a previous post:
You can make nice saw blades out of 1095 tempered tool steel from almost any industrial supplier such as MSC in the USA. For example, a 17-foot roll of 1" wide 1095 that's half as thick (0.015", which I prefer for a medium blade) as the ECE 1 1/2" blades (0.030") costs 35USD. This steel is conveniently tempered at Rockwell C48-51, is easy to notch and tooth, holds its edge well and sharpens properly. Skip to page 1747 from the link below and make yourself a set of IT-like DT and carcase saws while you're at it (25" x 6" x 0.0120").
1095 steel in rolls (flat sheet on p1747)
Re: Saw blade steel
Re: Saw blade steel
wayne
>Thanks, I use MSC for other things but didn't know they had tempered steel there book is about 500 lbs.
