Have a question? Ask Woody!
Sharpening: newbie follow-up
VTAndy
>Hi,
A while back I had posted some questions about grinding and sharpening.
A friend who builds violins gave me a very nice lesson on sharpening. The blades I wanted to work with were the blades that came with the old Stanley #7 and #5 that I had acquired about a month ago. We discovered that the bevels were at quite high angles -- around 40 degrees -- and so we decided to lower them to around 30 degrees. We did this on a Tormek. My friend first showed me how to dress the wheel, and then we established new primary bevels on the 2 irons. We then honed them on waterstones. I was very satisfied with the sharpness that I was able to achieve. And generally, I found the Tormek surprisingly easy to use.
I have enjoyed learning about the techniques that different people use for sharpening. This friend is a violin-builder by trade, and he uses the waterstones in a different manner than I've seen before. He holds the waterstone up on end, sighting down it, holds the blade in the other hand and passes it only once -- or twice if necessary -- down the length of the stone. Difficult to describe, as I just now realized. However, since he works only with razor sharp tools, it is apparently effective for him.
So, I'm happily experimenting! And I'll probably continue to work with a variety of methods for now.
One question, however. The old #7 actually came with two blades. One with a mostly straight edge, slightly curved off at the edge, and another that is radiused. I haven't used the radiused blade yet -- and we noticed that that blade is warped. What can I do about that? Is it worth working on or should I just forget about it? We didn't touch this blade in our sharpening exercises.
-Andy
Re: Sharpening: newbie follow-up
Bob Hackett(Mainely,Bob)
>You`re very lucky to have someone who`s competent take you under his wing,nothing shortens the learning curve like one on one instruction.
The one thing I feel is most important about sharpening is to decide on and learn a technique and then stick to it.Many times the technique you decide on will be dictated by the type of equipment you can either afford or have access to.There are many cats out there,pick one that appeals to you and practice skinning it.
Your old iron can serve as a teaching aid if nothing else.I`ve had some luck straightening both plane irons and chisels by centering the high spot over a pair of hardwood blocks and tapping the high spot with a brass mallet.It takes some practice but...
Your mentor may have a better way to do things,I`d ask his opinion first.
Sounds like you`ve lucked out finding this friend.If it were me I`d do all I could to stay in his good graces.
Mainely,Bob
