How to Sharpen a Miter Trimmer Blade?
Dave Thompson
>I just picked up this Oliver miter trimmer from an auction. Oliver made some monsters that had ship wheel handle for blade levers, but my Oliver #0 is a little bench top version and is about the same size as a lion miter trimmer. The blade is in good shape, though, I do see a little tearout when I trim. Not sure yet if I'm just taking too much off, or perhaps the blade could use some honing. Anyway, I'm not having much luck coming up with ideas for how to sharpen the blade.
It has a single double edged blade. It's 5/16" thick, 3x 3/4" wide(high), ~11" at top, and 4" at bottom. The skew on it is 45 degrees. How does one sharpen a beast like this? I had thought about just lapping the back, and may use that as a fall back.
I did a little probing around the web, I see the lion trimmers have two separate small blades, and the instruction say to send it to Lion for sharpening ($35.50 + shipping fee). I'm thinking about contacting them and find out if they'll do the Oliver blade if I can't find another method.
How is this handled with the Lee Valley trimmer blades?
Thanks for any ideas you may have.
Dave
