What's your favorite cordless drill?
Dave Thompson
>Not wanting to be confused for an electron-phobic, I'll admit, my black&yellow, single hand operated, 14.4volt cordless will likely never be replaced by a yankee screw driver. However in the workshop, I find myself using hand drills for pilot holes into hardwood almost exclusively recently. Initially it was because I was concerned about the 14.4 volt batteries being in a freezing unheated shop, and I didn't feel like making the trek indoors to retrieve it. Those replacement batteries can cost about as much as a car battery each, and after 8 years now, both are going down hill fast. Over the past couple of years though, I just grab one of the Millers Falls hanging on the wall out of habit. Ok, now that I got that out of the way....
I find myself tempted to collect a few of these. I really have grown to appreciate the well made and attractive Millers Falls drills. They're common and under valued on e-bay, IMO.
My most used one is a No. 5 (right side). It's a nice size for bits that are 1/4" or less. It comes with a second idler gear to equalize the bearings. It has very smooth action. The handle will hold some bits. Originally it came with 8 bits 1/16 - 11/64. Though when I got it, it had none. It sold for $2.00 in 1915, and weighs less than 2 lbs (according tot he the MF catalog). I think I might have paid $15 on e-bay.
The middle one is a No. 2. The larger size and weight make it a little easier to handle slightly larger bits. Frankly I don't use this one so much. The wood handle wobbles and I can't seem to break free the screw that attaches it to the body. It's so stuck, that I wouldn't be surprised if someone epoxied the threads, or perhaps spot welded the screw in place. Regardles, I haven't found a way to remove the handle wobble without destroying it. It sold for $2.92 in 1915. It's 14 1/2 inches long and weighs in just under 2 1/2 lbs. I think I paid $20 about two years ago. My experience from e-bay was that collectors will bid pretty high for model in good condition. I think I remember seeing No. 2 NIB for ~$120. I suspect these are collectors, only because as a user, I prefer the No. 5, which often seem to be cheap.
I just recently picked up this 980 (left). It's the heaviest at 3lbs 2oz. The white metal ring just inside the main drive gear is actually a speed changer (two speed). By twisting it, one can change the speed ratio from 1:1.5 to 1:4. It has very smooth action. The low non-action handle is nicely positioned for holding the drill while drilling. I only just got this drill two weeks ago. The chuck was initially frozen. With alot of WD40, they work pretty well now, though the jaws don't quite spring back yet without a light touch of the finger.
I've been eyeing a Goodell & Pratt two speed drill for a long time now. I was lured by the gizmo factor of the two speed gear mechanism until I got the MF No 980. All of the ones I've seen are in rough shape.... not quite sure why, but suspect it may have something to do with the age that manufacturing may have stopped.
Enjoy,
Dave
Re: What's your favorite cordless drill?
Dave Thompson
Do I get just one? No, you had several
Bill Houghton, cold and rainy in Sebastopol, CA
>so I can too.
Push drills, any brand, though almost all of my working ones are North Bros (Yankee) or Stanley (bought North Bros).
North Bros Yankee type eggbeater drill, of which I'll try and post a pic tonight.
For big stuff, I like the M-F No. 2, but have the same problem with wobbly handle. I think they used inadequate wood for those handles.
Steve Kubien
Steve Kubien
>I'm a little drill poor at this point but planning on stepping up soon. I've got a couple of Yankee 41's along with a Handyman with the non-twist bits. Love 'em all. As for eggbeaters, my MF #5 (I think) gets a lot work. I've also got a newer Schroeder (SP) which I use occasionally and a Stanley 12-something. The Stanley hasn't been used in a long time. A bigger MF, like a #2 will be next on my pursuit-and-capture-eggbeaters list.
Now that I think of it, I don't even have a working electron-fired cordless drill. Haven't missed it in the shop at all.
Steve Kubien
My favorite or a late PATINA report
Skip in Falls Church
>I picked up a Yankee 1545 at PATINA to add to the MF #2 and #5 I had. It looked okay (if well used) but it turned very stiffly, the speed selector only worked on high speed, the function selector wouldn't move and there seemed to be an obvious issue inside the chuck. But it was only $10 and I figured it wouldn't be that hard to get it working right again.
After a good cleaning and oiling it was turning okay and the function selector was moving easily. The speed selector required disassembly and a bit of work to get the low speed plunger free - but then it was working working fine.
But no matter what I did to the chuck it kept sticking in the closed position and it took a pretty heft rap with a mallet to get it unstuck. So I disassembled the chuck and cleaned it - but it was still sticking. I finally took some sandpaper to some rough spots inside the chuck then oiled the heck out of it and it's working pretty good now although it has a tendency to stick in the full closed position. A good rap with my palm will get it to retract though.
In any case, it's fun to go through the different speeds and functions (plain, left ratchet, right rachet, right double ratchet - okay, lock is not that fun.)
Skip
Little Yankee
Don in Northern Arizona
>Well built, feature-ridden, and homely.
Don
Or Big Yankee
>Same as above only homelier.
Don
Can't forget the baby
Re: Here's a sample...
Dave Thompson
>Wow Scott, So you collect Record planes, and metal braces. What else do you collect? Auger bits?? ;-)
Very nice by the way.
I'd love to see more of your collection if you get the gumption to post.
Yankee pics
Dave Thompson
>Very interesting Don. Thanks for sharing.
North Bros Yankee drills *LINK*
>It's been interesting to see how many of us like the North Bros drills, especially since the Millers Falls drills have so much "name."
My two little 1530A drills (see ad text below for the 1530, which is similar) are terrific tools for small holes, though they're a bit undersized for anything above 3/16". The five-way ratchet, mentioned by Skip, is really cool - plain is of course plain. The right and left ratchet are similar to the Yankee screwdriver right and left ratchets, though few of us have enough left-twist drill bits to make much use of the left ratchet. The right double ratchet is truly fine: no matter in which direction you move the crank handle, the drill turns right, which permits me, through some law of physics I don't understand, to get much-improved torque for larger drill bits by wiggling the handle back and forth with vigor. Finally, the lock feature permits REALLY cranking down on the chuck to get the bit tight, or REALLY opening it up.
The 1530 is similar to 1530A
and a snide addendum *LINK*
>Martin J. Donnelly has a 1530 on his site right now, which he bills as a "multi-speed" drill. Well, yes...since the spindle speed is determined by how fast you crank, you could argue it's a multi-speed drill (indeed, infinitely variable speeds!), but I think he confused the various ratchet choices with speed controls.
Martin J. Donnelly's ad mentioned above
Pump drill
David Barnett - SW Florida
>Don't get me wrong, I love my MF and Goodell-Pratt eggbeaters, but my absolute favorite is an inexpensive (six dollars a couple years ago) but well-made pump drill from India. It has a nicely finished brass flywheel, precise chuck for smallish to tiny drill bits and a nicely turned hardwood pump bar that slides over a polished nickled shaft. Only thing I've ever done is replace the cord with a string I made from Kevlar thread.
It's just so easy to just grab it or just hand onto it and start drilling -- and with one hand. Once you get the hang of it you're hooked. Since it drills both clockwise and counter, I use straight fluted or flat drills, which I mostly make myself out of sewing needles or drill rod up to maybe 5/32". You can flare (forge) the ends of a smaller rod, so you only really need a couple diameters on hand). Twist drills will work but it's rare that I chuck one.
Not for deep holes, of course, but for small hardware, piercing sheet metal, marquetry, and so on, it's a pleasure to use.
Erratum
>"to just grab it or just hand onto it" should read "to just grab it or just HANG onto it", of course.
Re: North Bros Yankee drills
Dave Thompson
>Your's and Don's posting of North Bros, have been educational for me. I wasn't aware of these.
BTW, I was looking at your shop on the web. A couple of comments:
That Stanley 624 you have looks interesting. I like your organization racks (saw till, H&R woodie rack, drill racks, new cabinets). I don't think I've ever seen Forstner brace bits.... interesting. Your collection of old tools looks like you've been discriminating, or you have another barn full of all the lesser duplicate functional stuff ;-)
What the heck are those wheel bearing doing on your Stanley #3?
Re: Erratum
Dave Thompson
>No fair David.... you can't tell us about a nice working $6 nickel, brass, turned hardwood handle drill, without at least giving a reference as to where to get one or who made it. ;-)
Is it Anant?
Are you confusing me with Scott Burr?
>or someone else more organized than I am?
Wheels on a No. 3? Maybe it's the race model.
Not sure then... Here's the wheeled #3
Dave Thompson
>Sorry Bill, I thought that hyperkitten.com website that the drill add came from, was yours.... So who's site is it? The plane I was thinking of is:
Dave
Now wait one minute...
Scott Burr in Ben Lomond CA
>I�m NOT a collector!
I just have a thing about complete set of certain tools� Yea, that�s the ticket�
Ahhh, I�m probably in denial�
That�s and old picture. There a few more Spotford�s in it now.
Re: Not sure then... Here's the wheeled #3
Alice Frampton, UK
>Josh Clark's site I believe. A bit of discussion about the #3 here.
Cheers, Alf
Hyperkitten is ...
Raymond in Trenton, NJ
>Gwen (the cat), companion to Joshua Clark, fellow Neander, Galoot and all around nice guy.
Raymond
who's wondering if Josh's going to CRAFTS in Flemington, NJ this year?
Re: Training Wheels *LINKS*
>Well, if you've ever contemplated the need for one of these, 386, or one of these, fence, or felt the need to attach one to a smaller plane, it might not seem like such a crazy idea.
Dave Thompson
>Yeah, that thought crossed my mind, though for a #3??
Maybe it's intended to be used as a #95.
