Raised panel
Raised panel
Raised panel
chichi
>Could someone describe the process for making a raised panel. I tried on some scrap by scribing a line about 1.25 inch in from each edge and also made a line about 1/3 depth around the 4 edges. I then took a stanley # 6 and angled the plane and went at it.(Blade parallel to sole, whole plane angled). The results were almost acceptable if I did not care about crisp straight lines delineating flat from top angled sides. Surely there is a more controlled approach than merely judging by eye. My method was fun and fast, just inaccurate. Does it get better with practice or do I need a better
plan of attack?
Thanks for your comments. I hope I dont need to purchase another plane.
Bob
Re: Raised panel
Re: Raised panel
Pam Niedermayer - Austin, TX
>You may want to try using a batten to help get those crisp edges, and a very sharp blade.
Pam
Re: Raised panel
Re: Raised panel
Ed Mulligan, Cape Cod
>Bob �
You are making a fielded panel. A raised panel or raised and fielded panel would have a center section with vertical sides raised above the beveled edges of the panel.
For a crisply defined center panel, raise it with a rabbet, fillister or shoulder plane. Then bevel the edges with your #6. The #6 won�t get into the corner. A shoulder or rabbet plane can clean up this detail.
To get a crisp(er) fielded panel with your #6, clamp a beveled fence to the sole. The fence bevel will help a bit with maintaining the desired bevel angle but your developing skill will be important too. To assist with maintaining the bevel angle, set a bevel gauge so it is perpendicular to the bevel angle and place it in your line of vision.
Ed
Re: Raised panel
Alternate visual reference
Bob Hackett(Mainely,Bob)
>I find it easier for me to place a thin metal rod or a length of small diameter dowel in a hole drilled to vertical in the fence that is clamped to the plane.Sort of an extended spring line.
Another thing I try to do is to remember to plane the endgrain fields first.That way if theres any ragged corners(there`s a special word for this but I can`t remember it) they`re planed out when I do the long grain fields.
MB
Re: Raised panel
Re: My method....
Dean Lapinel
>Jamey,
Nice photos and that plow looks like fun!
I always use a haunch mortise but have not had it go through as yours does. Visually...for those that know what it means, it is nice but does the through mortise have any structural weakness as compared to the typical haunch?
Re: Raised panel
Shouldn't be any less strong....
Jamey Amrine
>The only drawback I could foresee with a through tenon is that as the stile shrinks, the end of the tenon could protrude. The stiles are narrow enough that that part shouldn't be too big a deal though. Shrinkage across that width should be minimal. I think the through tenons are more traditional for some styles. When I created the F&P for that page, I was going by the example in St. Roy's book, and that is what he did. The last few F&P's I have done have been blind mortises.
I will mention that I did haunch the tenons, as is necessary when you have a groove that runs the length of your stile. I have also seen examples with open mortises, which if used for doors, I would think should be plenty strong. With today's glues, I would think an open mortise would be a fairly strong joint regardless of application.
Re: Raised panel
Spelching?
Joe Rogers, Northern Virginia
Re: Raised panel
Re: Google?
paul womack
Re: Raised panel
There it is!
Re: Raised panel
New tools needed
Ron in Kokomo
>Get a door set
Three specialized planes to cut the panel, the rail and the stile.
Such a total joy to use. Tod Herrli made mine
