Mouth Sizes & Smooth Plane Performance
tonyr
>I have recently spoken with a few folks re: whether a fine mouth is important for optimal smoothing plane performance. One told me that it is critical (the narrower the beter, up to perhaps 2 thou or so), another that it makes absolutely no difference (the wider the better, within reason) and the third that up to 55 degrees or so it does make a difference, but that beyond that (eg, 60 degrees) it makes no difference.
I would be most interested in hearing any views on this topic from the many experts that frequent this site. For my part, i define smooth plane performance as the ability to take a fine (ie, very thin) and uniform shaving while leaving a smooth, tear out-free surface. Also, i'm principally interested in function of both bevel up and bevel down planes, if that makes any difference.
Last, for those of you that subscribe to the fine mouth view, how fine a mouth is optimal?
Many thanks for the thoughts, tony.
Re: Mouth Sizes & Smooth Plane Performance
Rob Millard
>I�m firmly in the camp that says the mouth opening makes no difference, at least on a bench plane. I have the mouths on all my planes set fairly wide, and I get excellent results. I think the position of the frog should be such, that maximum support is given to the iron. As an example, on my 1970�s era Stanley No.7, if I had a tight mouth, the frog would have to be forward and the last bit of the iron wouldn�t be supported as well.
There is no question that a higher bed angle is better for working in difficult grain. I have no experience with planes bedded at anything higher than 52 � �, so can�t comment on the usefulness of a 60� plane.
I made my own wooden plane and bedded the iron at 52 1/2�; the iron is piece of 3/16� A2. This plane will take a very fine shaving in any wood I�ve tried it on. When I first made it, it had a pretty tight mouth ( no where near .002�, but tight none the less) , but it clogged with shavings too often, so I opened the mouth to almost 1/8� and it still takes very fine shavings in any wood. I have since replaced that plane with a LN 4 � with high angle frog, and use the wooden plane as a scrub plane. I like the heft of iron for a smooth plane.
As far as bevel up planes go, here again I have no experience with them, other than on end grain. I will say, in my opinion, that in order to get a higher cutting angle with bevel up planes, the blunt grind angle required, wouldn�t work as well as a bevel down plane, set at a higher bed angle.
Rob Millard
Stephen Kirk in Quakertown PA
>While I haven't tried this empirically yet, using the LV LA Jack (bevel up plane), setting a tight mouth does seem to have quite a difference. Working on Oak, I saw a lot less tearout using a tight mouth than when using an open mouth. For any thick shavings, when I'm trying to correct the surface first, I definitely use a wider mouth, but usually just wide enough to get the shaving through. I've just been working some fir boards (hey, legs for a bench, why buy expensive stuff!), and that wood seems to like a tight mouth as well, or it tears out easily. I don't have the high angle blade, so I have no experience there to offer.
I have used my old Millers Falls with a rather wide mouth (1/8" or more), and I do seem to get pretty good shavings, at least on straight grained wood like maple (not curyl). Oak had more tearout.
I try to just do what works. If your using a wide mouth, and getting tearout, try tightening it up, and see what happens. Different woods allow different plane settings, that's for sure, and unless your a master, some woods will just need scraping or sanding to get smooth.
Ed Mulligan, Cape Cod
>Tony_
For common hardwoods my preference is for a low angle, bevel up plane with an easily adjustable mouth. I sometimes use higher attack angles in a LABU plane. It works great although at a cost of slight increase in effort and more frequent sharpening.
As attack angle increases, mouth opening becomes less important. On a 112 scraper plane the mouth opening is �� or so, with no tearout.
To avoid jamming, a small mouth opening requires a very fine set to the iron which results in very thin shavings which indicates very slow removal of material. A wider mouth will allow thicker shavings but at greater risk of tearout. That�s why I like an adjustable mouth. Dial it wide for easy woods, narrow for more difficult stuff.
Ed
Greg Sloop, Portland Oregon
>I've done a lot of informal testing on this very issue.
FYI: All the situations I've tested it in are on bevel up planes - LN and LV Jacks and smoothers. This shouldn't really make any difference, as the wood doesn't care a whit about which way the bevel is, but only in the angle of cut and how well the carrier, or plane, holds the iron. (Chatter and stability etc.)
Given this, here's what I found.
On forgiving woods, oak etc, virtually any angle will work great. Even 37 degrees works fine. (Too high of angles appear to produce less than optimal results, so use the lowest available that produces a good surface.)
On more difficult woods, the impact from changing the angle far outperforms that from mouth adjustment or even depth of cut. (Rank-ness if you prefer.)
I took a piece of QS Sycamore sapwood with lots and lots of figure. (I�d already finished the board with no tear-out at all, using my high angle iron.)
Using an iron at 50 degrees, I closed the mouth as tightly as I could. Took the lightest cut possible and tried to plane this board.
Immediately, you could feel and even hear the tear-out happening. Every pass left some tear-out. It was quite small, but very visible. Once a finish was applied, the tear-out would have been very, very obvious.
I then took the same plane, and put in a 65 degree iron. I closed the mouth down as tight as the previous passes with the 50 degree iron. In just a few passes, I was able to easily remove the tear-out from the 50 degree iron. (Further, the 50 degree iron had just been sharpened, the 65 had many passes on it already�so the 50 should have performed better as it was likely a lot sharper.)
So, once I knew it would clean up all the tear-out and leave none itself, I started opening the mouth. I could basically open the mouth as much as I wanted without producing tear-out. I took a much heavier cut too. Both mouth size and cut depth had far less impact than cut angle did.
Here�s my belief: Where a small mouth makes a large difference, the mouth is simply a crutch that helps limit how much tear-out one sees, rather than actually keeping the tear-out conditions from occurring. (Kind of like a shaving razor that is dull and automatically applies coagulation compounds to your skin as you shave. It leaves nicks and cuts everywhere, but since it stops the bleeding really quickly, you can�t really see the damage it�s doing�)
IMHO, a tight mouth solves tear-out simply by holding the fibers of the wood down until just before they reach the iron and thus you don�t have the tear-out running way up the board and getting deeper and deeper. Thus the tear-out you get is small, but it�s still occurring. (ie. The conditions to create tear-out still exist, you�re just limiting how much you see.)
The problem with this, especially on the QS Sycamore I�ve tested on is this � at least according to my theory and experience. At least some reversing grain won�t have tear-out that runs up the board. The tear-out is going to occur mostly vertically and thus even a super tight mouth isn�t going to be able to hold down the run tear-out much, since the tear-out isn�t running outside the mouth anyway.
Adjusting the cut angle changes the dynamics of the cutting process itself. The higher angles appear to force the wood to compress and cut cleanly, thus needing the mouth to hold it down so you can cut it rather than split it isn�t needed.
However: A very tight mouth does have one advantage as I see it. It holds cut depth to a very tight range of cuts. You can�t flex the plane nearly as much so you can�t change the cut depth much at all simply by pushing on the plane.
I have no time left to expand on this right now, but I�d be glad to elaborate as needed should questions arise.
Cheers,
Greg
Dan Clermont in Burnaby
>Hi Greg,
With good contact on the sole just prior to the blade and with a tight mouth you should be able to hold the fibres down and get no tearout. Are you sure the plane you are using is dead flat across the mouth area and that area is making contact with the fibres?
I don't seem to get tearout with my 50 degree planes on highly figured maples and the exotics I have tried. Right now I am working some highly figured bird's eye and this wood planes easilly at 50 degrees with a sharp blade
Dan Clermont
Cheers
Dan Clermont
>Dan, it appears you don't seem to understand my point.
If the angle of cut is appropriate, you need no mouth at all. Inches of gap, or certainly tenths of inches will work just as fine, or almost, as .002"
The comparisons I've done are on the same plane and different cut angles - doing this with several different plane bodies. With the right amount of tweak, I can make tear-out stop, at least given a high enough cut angle. But once the, IMO, "proper" cut angle has been reached, it becomes clear that mouth size really isn't the issue - cut angle is. You can take pretty rank cuts, with a mouth wide open and still control tear-out.
When you're using a too low cut angle, you can fuss and fuss...close the mouth, wet the wood, take powder shavings, reverse the planing direction etc etc etc. None make a huge difference, and if you deviate at all, open the mouth at all, take a slightly too thick shaving etc, it all falls apart.
Thus, I *can* control the size of tear-out by adjusting the mouth. However, that's exactly what's going on - control or mask of the symptom.
If that's the best one can do, it's fine I guess. Likewise, if you have to shave with that nasty dull nick and cut razor, then the auto-coagulant application system is a great deal. At least you won't bleed all over your shirt and the bathroom. Still though, it's hard on your face and makes the whole process needlessly complicated.
I'd much rather have the sharp razor and leave the slick automatic coagulant dispensing system on the shelf.
Using the correct cut angle makes the need of tweaking mouth opening super tight a solution on search of a problem, since mouth size is simply not an issue any more.
So, sure, one can focus on the uber mouth opening issue (or the ultimate coagulant application system) and fix symptoms, but I personally don't think it's the best way to solve problems. Solve the problem at its source and you don't need to find other ways to mask a problem you already have.
Cheers,
Greg
>Hi Greg,
Sorry, I agree and disagree.
I agree that the higher the angle the less the importance the tightness the mouth makes. This is why scraper planes don't have a tight mouth.
I do believe that one can achieve a tearout free surface with the following:
-tight mouth
-thick blade
-good pressure across the mouth
-good blade support
-most importantly is the sharp blade.
I don't own a plane with a blade bedded at more then 50 degrees and don't own or need a scraper plane
Tearout can be eliminated without scraping or planing at 65 degrees
Check your plane for a flat sole and sharp blade
Dan Clermont
>Tearout can be eliminated without scraping or planing at 65 degrees.
On your wood or choice, perhaps. That isn't the case here.
You must not have wood that is difficult to plane at 50 degrees and less. If that's what you work, and you don't need anything else, then that's great.
However, Lynn, Derek Cohen, myself and numerous others have found that regardless of what you do with a mouth etc, that adequate cut angle is simply a required to get woods we work on a reglular basis to yield the best tear-out free results. See Lynn's high angle plane study.
Simply stated, for many of the woods we work, 50 degrees is simply not adequate - no matter the shapness of the iron, the tightness of the mouth etc.
If you're not working those woods than don't worry about it. But clearly the concensus from many of us from close observation is that cut angle is very very important and picking the proper cut angle will make your life a lot easier.
FYI: My plane(s) is/are flat, my irons are sharp. You're making assumptions that all woods are like the ones you're working. And that's a false assumption. I know from experience. (IMHO, figured maple isn't that hard to plane well, even at angles far less than 65 degrees - at least from the pieces I've done.)
So, in short, you're planing a relatively easy to plane surface and claiming you've done so successfully. Sure, you have. But that's not a test of cut angles vs mouth size - you're not even reaching the failing point of the technique. (Even a Dodge Aries can do the quarter mile if you put the cut-off times at 60 seconds.)
If you want a real test, drop the cut angles until they start to fail on the maple. Then see what makes more difference - mouth size or angle. You'll probably find that angle is a lot bigger influence. This is exactly what I've done.
Cheers,
Greg
>Hi Greg,
Send me a piece of QS sycamore that gives you trouble and I will plane it for you.
See allot of highly figured woods out there that were tamed well before the invention of the BUS
Ping me offline for my address
Cheers
Dan Clermont
Greg, what's a good angle then?
Gary B in Central NY
>I'm curious, as I want to build some wooden smoothers...I was thinking of 50 degrees, but now, maybe I'd want one at 50, and one higher? as for the higher angles, do you find this affecting the edge retention of the blade at all? thank you for your thoughts.
Gary
Re: Greg, what's a good angle then?
>Hi Gary,
If it were me I would build the 50 degree smoother with a tight mouth and flat sole. Try it and see if you need to go with a higher angle of attack.
I talked to a friend tonight who has successfully planed QS Sycamore at 45 and 50 degrees (50 degrees left a perfect surface). Although I haven't planed this specific species I have not had tearout problems with my 50 degree plane and don't see a need to go higher then that.
Cheers
Dan Clermont
Pam Niedermayer - Austin, TX
>Seems to me the ideal angle is related to the wood being planed, at least in bevel down wooden Japanese planes. What follows is a list in progress developed by a friend who was a Japanese tool vendor years ago, with a little of my help:
33-37� kiri (paulownia), sugi (Japanese cedar)-soft wood, western red cedar
38-39� hinoki (Japanese cypress), matsu*(pine)-common or ordinary wood
40-41� kuri (chestnut), tsuga (hemlock spruce, boxwood)
40-40� Birch soft, cypress, pine, medium soft woods
40-42� walnut
41-41� willow
41-42� maple soft
42-43� keyaki (zelcovia), sakura (cherry)
42-43� elm
42-45� oak
43-43� beech, birch hard, maple hard, keyaki (zelcovia), sakura (cherry)-hard wood
43-45� chestnut**
45-45� teak
52-52� ebony, rosewood kokutan (ebony), shitan(rosewood)-hardwood-kyubobai (steep slope)
*Note, matsu or pine in Japanese includes white pine, red pine, black pine and silver fir
**Apparently these aren't the same wood
The angle is measured as the angle between the sole and the top of the blade (the non-bevel side). In practice, it's very difficult to obtain precise angles because of construction techniques, but you can get very close.
Pam
PS Please note that the seemingly unnecessary angle repetition when only one angle is recommended is purely for spacing problems here, seems embedding spaces is not allowed.
>Got so involved in spacing out the table I forgot to mention that I agree with Greg that the small mouth controls rather than prevents tear out, at least in theory. Not quite sure how I'd prove it since I don't plan to make test planes with huge mouth openings.
Also, I've found it doesn't always help to use higher angles to eliminate tear out. For example, a plane I made (a high 43 degrees) made a beautiful surface on cherry, but it tore out black walnut, which calls for 40-42 degrees.
For some reason I can't enter the degree sign here, use alt(option)-shift-8 on the Mac. Here that gets me a superscript "n."
Pam
Use the entity
Dan Donaldson
>Get the degree sign with the html entity ° °
Thanks, Dan °
Paul Kierstead
>That is quite a fascinating table, Pam, and seems at odds with conventional wisdom to some extent (not that conventional wisdom has some kind of inherent truth). It really makes me want to make a 40� plane and take it for a spin on some pine. Or maybe one designed for cherry (but is that american black cherry, or some other cherry?)
Hmm... this borders on semantics I think. I would imagine that all the techniques control rather then prevent tearout, just some control them to the degree that it is no longer visible/objectionable. It would seem to me that going down the path of prevent vrs control would be a bit of a dead end.
>What�s a good angle:
Good question.
First, a good angle is one that works well for the woods you use. If you use more common stuff like maple oak, jatoba, etc. then you probably don�t need the highest angles. If you do use tougher exotics � especially with a lot of figure then the higher angles are useful. In short, use the lowest angle that will still produce a decent surface.
In my experience in testing a whole range of cut angles, 37, 40, 45, 47, 50, 52, 55, 57, 60, 62 and 65 degrees I�ve found three that work best for me. (This probably isn�t every one I�ve tried/tested, but it�s most of them.)
37 degrees: This is what I use for end grain and puttering around. Long-grain/side grain Oak often planes just fine, so does poplar. You�d be surprised how much you can do. This is generally where I start if I�m not sure what to use.
LN also does a toothed iron at 37 degrees that I liked a lot. I think LV�s is at 45 total angle, and it works well as well. If you�re trying to remove deep tear-out or a lot of material, this is a great way to do it without generating even more tear-out. Less work than a regular iron, and since it�s toothed, it doesn�t produce tear-out. A few final passes with a high angle iron will clean it all up and leave a very nice surface. It�s a very nice trick to have in the bag, IMHO.
50 degrees: This is what I use on nearly everything else. Some Lacewood and QS Sycamore as well as some Walnut with inclusions/knots are recent examples of something that I couldn�t do on 50 degrees, but most stuff works well here. It�s a lot less work pushing 50 degrees than 65 too. I�ve tried 45 and 47, as well as 52. 50 doesn�t seem much worse to push than 45, and it�s a bit cleaner in some cases too. 52 isn�t much better, and it seems a fair bit harder to push. 50�s a nice compromise.
65 degrees: As you can see above, I�ve tried a whole host of angles from 50 up to 65. Above 57, things appear to get better � quite a lot, but still not as easy to get great results. Iron sharpness has to be very good, Mouth size and depth of cut is really sensitive. 62 works pretty well too. 65 seems optimal and not a lot different than 57 or 62 in terms of force needed. (You won�t be taking a very rank cut at anything above 55 or so anyway�) It�s easiest to get the perfect finish on the stuff I�ve worked with at 65 degrees, without having to resort to a whole host of gimmicks.
That�s it. Three irons covers everything I�ve ever done. There might be a case or two where you�d still have to pull out a scraper, but it sure isn�t going to be often. I tend to believe with a little futzing you can make almost anything end up perfect or virtually so with these three.
Edge retention:
Ah, here we get theoretical.
First, how would one test for this?
Second, do we even care much what the result is? (Perhaps, but I doubt it will make much difference.)
A board I�m going to plane at 65, simply won�t plane well at 50. Often the reverse is true too. So, lets assume, just for the sake of argument that a 65 degree iron will last half as long as a 50. (I don�t think for a minute this is true, but assume the fiction is fact.) Even if that�s true, what does it net a person? It�s not like I�m going to crank out twice as many tear-out filled boards with my 50 vs. perfect boards with the 65. I want a perfect board, or nearly so.
So, to test this, you�d have to use an objective, absolute measure of sharpness like Brent Beach does. (Hope I�ve spelled his name right�) You couldn�t use the surface of the board to measure it, because one will probably turn out a good surface and the other won�t.
Further, I�m not sure edge retention will be worse on a 65 degree iron.
As angles get larger you have two factors working against each other.
A) You have a larger angle. Larger angles tend to have more support and tend to last longer.
B) Larger angles will have higher forces acting on them (and the wood) thus likely losing a keen edge faster.
So at what angles does B overcome A? I sure don�t know. I don�t think anyone does. And, what�s the curve for the change. Is it linear, or an accelerating curve etc.
Knowing these things _might_ help us make more informed and scientific decisions for the proper angle given that several work equally as well in producing a perfect surface.
Finally, go look at the chip formation issues in the Sharpening book by Leonard Lee. You�ll note that all those cutting edges have no mouth at all. None.
The wood simply fails differently when a higher angle is applied, and IMHO, there�s an appropriate angle for every wood. When the proper angle is used, the results can be fairly startling as I�ve found.
Hope that�s food for thought.
I�ll also answer Dan here.
Dan, I don�t believe you�re even close to objective. You have a serious bent against LV for who knows why. You continue to claim that 50 degrees ought to be enough for everybody. You�ve even claimed that I should quit using QS Sycamore since it will prevent me from doing any wood-working etc. So, I don�t think it�s worth wasting anyone�s time and effort to send you a piece. (I guess I say, �Enjoy your Jihad.�)
What I can say is this, and it�s final. If you like 50 degrees and it works for everything you do, that�s great. I have no problem with it. Enjoy.
However, Lynn, myself, Derek and numerous others have found that 50 degrees isn�t enough for quite a number of situations. Since I�ve sampled literally like a dozen different angles on a single set of boards with no less than 5 different plane bodies I feel pretty confident in my conclusions. I don�t need you to confirm for me what I already know to be true. (I�ve tried most of these angles on a LN 62, at least a couple of LV 62.5�s, a LV heavy smoother, a LV BU Jointer, a LN 60.5 block and a Baily #7 at 45 degrees � and perhaps a few others I�ve forgotten�.)
The original poster asked about mouth size, and since I�ve done some pretty extensive personal testing I think I�ve got a pretty good handle on that discussion.
I�m not the only one that�s found the profound difference that total cut angle makes. Lynn, myself and Derek seemed to have reached the 65 degrees as our preferred angle pretty much independently. But perhaps you�re right and the rest of us are all on crank.
Oh, and BTW, there�s huge variation on QS anything. QS simply means it�s been sawn on the quarter. The figure on QS Sycamore, Lacewood etc, can go from looking nearly plain flat sawn to incredible.
The hardest stuff to plane is that where the rings are nearly tangential to the face of the board. (The rings are intersecting the board face at angles nearly parallel to the face.) Really big trees produce the best boards with lots of figure across the whole face. Usually you also get a lot of sapwood on these boards too and the sapwood is a lot softer and tears out a lot easier and deeper.
Cheers,
Greg
>Greg states:
Hi Greg,
I think your angles are a little steep. Most plane manufacturers have never bothered to build planes above 55 degrees. You seem to believe one needs to have a bevel angle of at least 50 degrees to plane anything. SOunds a little bit like a marketing ploy for BU planes.
My thought to have you plane a piece of QS Sycamore at 50 degrees and then pass it on to me so I could try a Bevel down plane at 50 degrees seems like a pretty controlled environment. The only vaariation then would be my abillity to sharpen compared to yours. Send me the QS Sycamore that leaves you tearout and I will see how it performs with a Bevel down plane.
Pam mentions down below some blade bedding angles which I consider to be much more realistic.
As far as a Jihad goes... with LV. I own several Veritas tools and will continue to do so. I think some of their items are great and others are not. I have recommended the Sharpening guides to several forum members in the past and have e-mailed Rob Lee to inform him how much I liked mine with a thought on how it could maybe be improved.
Cheers
Dan Clermont
>Yeah, these aren't conventional planes in the west. The table base was from a Japanese blacksmith (Tsunesaburo), friend and I have modified it over the last couple of years based on our personal experiences with western woods. If you make a 40° plane to test this, be sure and use very thick irons. The typical Japanese plane is offered as 38-42°, anything else is a custom order.
I suspect that western planes with flat metal soles and much thinner blades behave differently. The only commmonality I see is that, typically, higher bedding angles are used for harder woods and vice versa.
Semantics? Maybe, but, not to put words in Greg's mouth, I think Greg and I think that if you have a sufficiently sharp blade at the correct angle for the wood, you get no tear out since the fibers are sheared/cut off at the surface cleanly.
Pam
