Ashley Iles chisels
Ashley Iles chisels
Ashley Iles chisels
Tony Zaffuto
>Good afternoon all,
I recently purchased an Ashley Iles chisel, 7/8" English pattern, to try out before committing funds to buy a set. Gave the chisel a honing and set out to try it out cleaning off some poplar dowel pegs. The edge crumbled! I ground out the chips (by hand) and tried it again, this time in a piece of oak. Two strong taps with my mallet and the new edge is gone!
Anyone else have this problem?
Tony Z.
Re: Ashley Iles chisels
Joel
>the chisels are ground 25 degrees at the factory. add 5 degree microbevel on the chisel and see what happens. It is of course possible you have a bum one - it rare but it happens - but try that first. If that doesn't work call or email me and we will swap it out.
joel
800-426-4613
tools for working wood
Tony Zaffuto
>Thanks for the offer Joel, however I prefer to try to work it out by honing the edge back a bit. I suspect the edge was weakened by the hollow grinding and as you said the 25 degree bevel. If I find this doesn't do the trick, then I'll give you a call.
To all others out there, upon re-reading my original post, it came off as a rant and I didn't mean it to. Goes to show that one should read your post before hitting the "post it" button.
Speaking of Ashley Iles chisels Joel...
Scott Burr windy and raining in Ben Lomond,CA
>What's up with the American pattern ones? It seems that the set and a lot of sizes have been OFS for a very long time.
I've been eyeballing the AI butt's for a while...
No comments from the peanut gallery you sick little monkeys.
Re: Speaking of Ashley Iles chisels Joel...
Joel
>A classic case of demand way exceeding the factories crystal ball of how many to make. They should be back in stock shortly.
Thanks for the update Joel
Dean Lapinel
>"I've been eyeballing the AI butt's for a while...
No comments from the peanut gallery you sick little monkeys."
Scott, what a total letdown. I had an instantaneous sick little monkey post planned and with the next sentence you burst the brief gleeful moment...
Please leave the door open next time? :)
Dean Lapinel
>Interesting thread actually since I have had poor edge holding and chipping of my entire set of six AI chisels. I always assumed that it was just an inferior metal but now I wonder if I had a bad batch.
My problem is that I'm in the US (that's not the problem) and I cannot remember where I bought them. I probably have no recourse to have them checked.
Dean
Sorry Dean...
>I'll leave the door open for you the next time!
Re: Sorry Dean...
Scott in Douglassville, PA
You want a comment to that?!
snigger snigger
Chisel bevel angles
Patrick Gibbons, Houston
>I've had my AI chisels for a while and noticed poor edge retention on the narrower blades. My 2" chisel does just fine with a 25 degree angle but my 1/4", 3/8" and 1/2" chisels do much better with a higher angle. Adam C. talked about this once I think as a general problem with chisels with the larger widths having more success with a lower angle. I know the common knowledge has the old formula of bench and paring chisels needing different angles but so far I've found it to be more a function of the width. I think this is a good question to follow up with others' experience.
Re: Chisel bevel angles
Joel
>traditoanally bench chisels were ground at 25 with a 5 degree microbevel.
( a small microbevel gives strength without detracting too much from penetration)
Paring chisels 20+5
Mortise chisels 30+5 (or a little more)
Love me 2 times baby...
>Doh! wrong doors...
Y'all talking the front door or back Scott...
Don't make me quit you....;^)
