Stanley 78 look alike?!?
Gary B in Central NY
>Hey everyone,
I bought a plane of the 'bay, which I thought was a 78 stanley. it looks exactly like one, though it's missing the blade adjustment lever. because I want a user, I could care less that it's not a stanley, but what is it? thsi is what it says on it.
"Made in USA" in raised letters between the handle and back blade "frog".
Above the front blade location it is stamped "C201"
The blade says "Wards master quality"
It does have the fence, though not the depth stop. I also think it will clean up nicely. since I want a user, I think it'll work out. I bought it for 31.00 dollars, if someone thinks it's worth much more, let me know, I'll clean it up and sell it on ebay, then look for a usable 78. Thanks....
Gary.
ps. anyone tried using hardware cloth as an electrode for electrolysis? I'm just thinking of something that could be wrapped around the object.
Re: Stanley 78 look alike?!?
Bill Houghton, cold and rainy in Sebastopol, CA
>I'm not sure who made the Wards planes, but my Wards Master No. 4 plane is a decent tool - the iron stays sharp for a long time, and the adjustments work smoothly.
Jay Hanks, Columbus, Oh
>More than likely what you have is in fact a stanley or sargent no 78, made for Montgomery Wards. Many times Sears and Montgomery Wards used other makers to manufacture tools for them. Lakeside is another Wards branded tool. I do not think there is a special market for it so clean it up an use it. Jay
todd hughes
>...I think if it was worth much more it would have sold for much more the first time it sold on the ebay, eh?.....Todd
Jim DeLaney, Austintown, Ohio
>The early 78's didn't have an adjuster. Walter's book says it was added in 1925. It was made from 1884 ~ 1984. The earliest ones (prior to 1909) had scroll work cast into the handle. After 1909, the handle had a 'fish scale' pattern.
I have five 78's. Two without adjusters. FWIW, Sargent also made a similar plane, as did Ohio, and perhaps several others. Thay're a pretty common type of plane at flea markets, etc. The $31 that you paid wasn't a bad price, but it wasn't a particularly good one, either. I paid $2.50 for the last three (together) that I got. That's how I ended up with five of them...
Jim D.
Jack Guzman from Maine
>Hardware cloth that isn't coated (non-galvanized)should work.I have used both iron wire and small steel strainers(for holding small parts) when doing electrolosis.No idea on your plane identification.---Jack
Steve Kubien
electrolysis
Steve Kubien
>I can't help with the plane ID but what I have done to get the electrode all the way around and obeject to be zapped in bolt together a series of HEAVY steel butt hinges. It's worked great and the hinges are so thick and heavy that they ought to last a lifetime.
Steve Kubien
Ted in Minneapolis
>Hi,
I can't tell you much about your plane, but I have a couple of Wards Masters and they look exactly like Stanleys. I really like them because their blades are like magic, they get wicked sharp and stay that way for a long time.
-ted
