200+ woodworking book reviews
Travelling with hand tools
Kelby
>For Valentine's day, my wife signed me up for a five-day class at a local woodworking school. :) I'm planning to bring a few handtools with me (a couple planes, handsaw, chisels) to make sure I have sharp tools to work with. What's the best way to pack up an assortment of handtools for the daily trip back and forth?
It seems like it ought to be an easy question, but my tools never leave the shop, so I haven't run into this before.
Re: Travelling with hand tools
Re: Traveling with hand tools
Richard A. Gillespie, Jr.
>I built myself a wooden tool case modeled after an antique I bought years ago. To keep the weight down I used poplar. I designed it to include casters on one end so I could pull it on smooth surfaces. The case is 30"(L) x 9-1/2"(W) x 24"(H). There is one handle on top and one each on the ends. However, when loaded with my planes, the case is darn heavy.
There is a flip top on a piano hinge and one tray. The corners have brass reinforcements.
Kelby
>Richard,that sounds really nice. Any chance I could persuade you to post a picture?
Re: Travelling with hand tools *LINK*
Ed Mulligan, Cape Cod
>I use a riggers bag. Mine's 25+ years old, is used regularly and shows little wear. If I'm carrying a large panel saw it fits between the handles.
Ed
Riggers Bag
Paul M. in San Diego
>Hi Kelby,
Here's a solution I've used. Ugly but it works.
Ugly... I warned you
>With the work I've had to do on my parents' place the last few years, I've just tossed - er, carefully placed - the tools I needed in a Craftsman toolbox. Unless the school you're attending is down a dirt road, I don't know that you need to be fancy. I should mention that I have those little plastic caps for the chisels, to keep the edges protected.
If you don't own a toolbox already, it might make sense to buy a plastic rather than metal one.
Toolbox pics (*pics)
GolfSteve in Calgary
>Here's an example of my toolchest which I have used to tote my tools to a hand-tool class. Not the best example, but it worked. When fully loaded it was too heavy for me to lift into my car.
The basic box was a chest made by students of the school where the class was held. The students had the option of buying their project or else the teacher could sell the project for the cost of materials. I bought the basic box for $40, getting a reasonably nice maple plywood box with some heavy duty handles and locking hasps. The locking hasps were nice because we left our tools in the school overnight. The heavy duty handles are not visible in the pictures, but they are simple "Stanley" heavy duty metal handles commonly available at hardware stores.
I installed the saws and a panel gauge into the lid.
The larger planes are french fit into a false bottom on the lowest level. The only problem with this is that I have to remove the lowest till to be able to remove the jointer plane. Kind of a PITA.
There's two sliding tills (which are very simple boxes) riding in maple runners screwed to the box sides. The lower till holds "stuff" such as drill bits, scrapers, etc. The upper till holds small planes. There's also room for a box to the left of the tills, which I use to hold larger gouges. Chisel rolls are stored to the right of the upper till. The area to the left of the tills is filled with miscellaneous stuff when the box is in transport.
Here's a shot of how the small planes are french fitted into the till:
Another one of the students had a simple box with a nice design. You simply piled stuff in there, but it worked for transport. Here's a shot of his smaller toolbox:
Old carpenter's box? *LINK*
Michael Recchione
>I have one just like the one in the link - it belonged to my grandfather (a commercial one like the one in the link). I also have another similar one that my uncle made for himself (really nice - hand cut dovetails, gold leaf monogram, the works). These boxes can be heavy when full, but my grandfather carried his on his back while walking all the way across the Triboro Bridge from Astoria, Queens to the Grand Concourse in The Bronx, looking for work back in the 1930s and 40s. So it's doable. I also used to see guys on the subway with these back in the 1960s. (You could stand them up, and they had a handle on the end as well as in the middle so you could hold on to them either way. That's where the name "subway box" came from.)
One of these holds a typical finish carpenter's kit from the pre-electricity era (electricity wasn't available on building sites until probably the late 60s, early '70s). The kit included a crosscut saw, a rip saw, a back saw, a jointer plane, a smoother or jack, a block plane, a scrub, a couple of relevant molding planes, a level, a set of butt chisels, a couple of files, rasps, a hammer, a hatchet, some screwdrivers and other stuff that I'm not remembering and that might have varied from person to person - a fair amount of stuff and easily more than you'll need for your course.
The commercial boxes were made of plywood (3/8") and covered with sheet metal. They're pretty light when they're empty. If it weren't for the saw requirement, I'd suggest one of those canvas totes they sell at home depot. They're even lighter, but they're too short to hold a saw.
1940s carpenter's box
Re: Travelling with hand tools *PICs*
>I usually just toss whatever I need into this tool tote.
Like St. Roy's, it has one vertical side (so it won't bruise the thigh when I'm carrying it) and three sloped sides. The rack comes out, so I can hang it on the wall in the shop or on a support on the bench when I'm not traveling.
The tote is made of 1/4" tuliptree with a 1/4" lauan plywood bottom. If I need more tools for a particular job than will fit in this one, I have another one. The second one is a bit bigger, so it will hold a #7 and a #8 and a couple of slicks, and since it isn't glued up, I can knock it apart and put it on a shelf when I'm not using it.
Jim in Burlington Ont.
HD
>I bought a couple of Big plastic tote boxes from HD. They have wheels and 2 trays inside.
Re: Old carpenter's box?
Todd Hughes
>I see LOTS of old boxes very simular to this one all the time though most seem to be owner made. Very Common and can be picked up on the cheap [$5-$15...often with the tools]
... When I used to do blacksmith demos I used a small one [maybe about 2 1/2 ft. long...most are bigger] to carry my tools other then hammers and tongs in.Hammers and tongs went in a canvas bag inside a wooden box which my anvil sat on. Carried a cut down saw,hand crank bench drill, plane, dividers, files etc. in the box. Really worked well and imagine that is why you see so many old ones out there....Todd
Wow!
Kelby
>What a great bunch of suggestions! Thanks to all!
Michael's post got me googling for "carpenter's toolbox," and I came across this gem:
http://www.plansnow.com/dn3073c.html
Not surprisingly, the solution to every problem seems to be another project . . . .
St. Roy
George Makowski
>Kelby, Here is some more food for thought. Roy Underhill did a show on building a 1940's era carpenter's box. I believe the video of the show is available. I also found the plans on his Woodwright's Shop website at one point. One of his books has the plans for his slope sided tool tote. I have built a couple for my sons and they very handy.
When I went off to make my way as a carpenter, late 1970s, Sears carried a sheet metal large carpenter's box with saw storage in the lid, spot to punch out for your framing square and a single lift-out till. I still have mine. Maybe you could find a commercial type still in production.
Good learning!
George in AL
Re: Toolbox pics (*pics)
Cecil Nickerson
>Hi Steve, you�re mostly right, But the bottom of the box had dividers made up of half by three quarter pine to sort my planes and the smaller items like chisels, marking guages, dividers, and so on were in tool rolls and placed on top of the planes. Were I to do it over again I�d make the box a bit shorter and deeper so I could put a till over the planes. My wife has appropriated the box by the way. If you�re going to Rob�s class this summer I may see you there.
Best, Cecil
>Hi Cecil! Nice to hear from you; hope you didn't mind me posting a picture of your box - I thought it had quite a nice design.
I kind of doubt that I will make it to Rob's class this year. New baby is due in July and I have a huge project at work due in July also :-(( But, I will probably drop by to see what's going on.
Regards,
Steve
Re: St. Roy
Tony Zaffuto
>I also have one of those Sears boxes--mid 70's model. Mine was in pretty rough condition about 3 or 4 years ago and I searched high and low for a replacement with none to be found.
I rehabbed mine and it is still serving me well, although as I am older and wiser, I try not to abuse it as much as I did 30 years ago.
T.Z.
