Stopped-rabbet with handtools... how?
Conger - the Irish diaspora in Munich
>I need to install a 'back' in a recess at the back of a carcass put together using sliding dovetails. The back will simply 'drop' into the carcass from the rear, and will be fixed with wooden nails (yes, I have accounted for wood movement).
This calls for 2 stopped rabbets... i.e. ones that run from approx 2" from one end of the board to within approx 2" of the other end (top and bottom of carcass). Each rabbet is approx 0.5" by 0.5", and runs on the edge of two of the carcass boards over a length of approx. 24".
Now, I appreciate this can be done (after a fashion... leaving rounded corners that have to be hogged out with a chisel) with a router, but how can it be done using hand tools?
Oh... did I say... the wood is flamed maple.
Thanks in advance.... -gerard-
PS... I do hope I got the terminology right... or is it a dadoe I am looking for?
PPS... Only two stopped rabbets are required... the rabbets on the sides of the carcass are 'through'.
Re: Stopped-rabbet with handtools... how?
Paul in NJ
>Use a marking gauge to mark the length of both edges of the rabbet. This will give you a nice clean edge. Using a chisel chop out the ends of the rabbet to make room for the toe section of a bullnose rabbet plane. Use the bullnose plane working from the middle out to finish the rabbet. You can skip the bullnose plane using just the marking gauge and chisel especially in milder woods.
Paul Dzioba
Re: Stopped-rabbet with handtools... how? *LINK*
Marc in Luxembourg
>Nice to meet you here, Gerard. As Paul wrote you chop out with a chisel in order to make the plane fit in. Now you can take the rabbet plane too, you merely have to increase the chopped parts.
You can also make two cuts with an azebiki (see link) and chop only beginning and end of the rabbet. Then you better clamp a fence to guide the cut. That works pretty well for me for short rabbets. I mark the cut depth with an edding on the saw blade.
Marc
Azebiki
