Veritas - Innovation in Tools
Spokeshave Blade Holder
Hoa Dinh in Alameda
>Short of buying a Veritas� Small-Blade Holder, how do I sharpen the blade of a Veritas� Low-Angle Spokeshave with a Veritas� Mk.II Power Sharpening System?
I don't have the Veritas� Mk.II Honing Guide but may consider it. Its registration jig seems to be able to use as a blade holder. Can honing guide owners confirm this?
Any idea as how to make a blade holder?
Thanks,
-- Hoa
Re: Spokeshave Blade Holder
Jack Guzman from Maine
Re: Spokeshave Blade Holder *LINK*
>I'm not sure how that blade is shaped but this works for some small blades.---Jack
small blade holder
You don't...
Scott Burr in cold Ben Lomond,CA
>First off Hoa, I do these freehand. There's a trick to it. I know nothing about the LV shave you have. If it's at all like the kits they sell (it looks the same to me) then all you need to is this...
Take the studs that attach to the blade for ajustment and thread them into the other side of the blade. Bingo, you have two nice long holders (studs) to hold on to and with the width of the bevel you should have no problems holding on to it. Provided you can remove the blade adjusting studs any way...
mikew
>Hi Hoa,
Here's the MK.II honing guide, small blade holder and a low angle spokeshave blade. Note that I have not removed the posts, but the Shaptons sit fairly high and the width allows this use. Wider stones or ones which sit lower would affect not removing the posts.
Take care, Mike
Alice Frampton, UK
>Hoa,
At the end of the instructions for that shave there's a plan for a simple blade holder - any reason that wouldn't work?
Cheers, Alf
paul womack
You make one? The instructions that came with your shave, also available here:
http://www.leevalley.com/wood/page.aspx?c=2&p=44834&cat=1,50230
detail this.
BugBear
Ah hah!
Hoa Dinh in Alameda
>It more like ...Duh!...
I bought the spokeshave used with no manual. But I did go to Lee Valley's web site and check it out before and after buying. Somehow I totally missed the instructions. I think a visit to my eye doctor is in order 8-(
Thanks, Folks.
-- Hoa
Bruce Branson
>In the instruction manual that comes with the spokeshave there is diagram that shows you how to make a holder.
Different design, Scott *LINK*
>The low-angle aluminum shave uses a simple flat iron (no, not a flatiron - different craft, that) that is clamped in place by some specialized machine screws, but they don't attach to the iron, just clamp against it.
As pointed out down below, the instructions explain how to make a holder. If you didn't get those, Hoa, you can find them on the LV website. I've tried posting the reference below, but don't know if it'll work - if not, just go find the spokeshave at www.leevalley.com - the link is at "Instr" right next to the price at the bottom of the catalog description.
About the spokeshave
I've always had good luck...
Scott in Douglassville, PA
>...just hand-holding the iron with the bevel flat against the stone. No jig required.
