Grinder vs. coarse sandpaper/waterstones
VTAndy
>Hi again to everybody.
More questions from a newbie. I'm going to put them in two separate threads since they are not really related.
Sorry for the long-winded build-up to the question. Here is the gist of it: do you have to grind with a "machine" (grinder vs. sharpening machine) or can the "grinding" be done on coarse sandpaper or coarse waterstones instead?
A friend has been teaching me to sharpen plane irons. The method he uses is to first grind a hollow bevel on a grinder, then use waterstones to flatten the back and hone the edge. The honing occurs freehand. The point he made to me is that you can "feel" where the bevel is (when honing freehand) if the bevel is hollowed.
Now, over the weekend after reading every nook and cranny of that amazingly long thread in which I became acquainted with a number of viewpoints on which planes to use to learn to surface boards and to joint edges, I acquired two old planes: a Stanley #7 and a #5 (corrugated, which makes it a 5C?).
I learned sharpening on our school's cheap 1990s Stanley #4's and spokeshaves. I was surprised to see how my "new" old Stanleys have even thinner irons.
I want to flatten the backs of these irons and sharpen them. I'm also wondering whether I need to work on the bevel. The method of the gentleman from whom I acquired them did not produce a "hollow" bevel. The prospect of sharpening thin irons with flat bevels using freehand techniques... yikes.
This brings up my question, which goes beyond the techniques that my friend is showing me, but I've been wondering about it: Can the "grinding", as "establishing the primary bevel" be done on coarse grit sandpaper/waterstones instead of a power grinder or machine (like the lap-sharp). Or are the sandpaper methods and waterstones only for flattening the back of the iron and honing the edge?
I've been reading the archives of this forum and others, as well as several books, and this still isn't clear to me.
Thanks again for all your patience.
-Andy
