REAL MILK PAINT
Wooden dado plane build question
Jake J. (Windsor, Ontario)
>What would the spur (the front knife that scores the grain) on a wooden dado plane look like? I'm toying with the idea of making one (a wooden dado plane) myself, but do not have a reference, or close up pictures of one to judge the difficulty in making one of these. Would the spur simply be wedged into the body like the blade? If someone could point me to a link or a book that has pictures of one of these, that would be even more helpful.
Re: Wooden dado plane build question
Dean J in MN
>Jake --
The knickers on a dado plane are as you described, wedged into the body like the blade. Most of my dados have it at a ~ 90 degree angle, but I have one that has it set leaning a bit forward. Makes no difference in use that I can see.
The knicker blade looks like a regular blade (without a bevel) with the center filed lower than the edges, forming a knife edge on both sides the width of the main blade. Like: ^_^ (bad ascii art there). The bevel is only on the insides, like a spur on an auger bit.
Wish I had a photo handy, reading that description is not helping...
-Dean
Jack Guzman
>Here's a sketch I made for Jim Reed when I had him make me one for a 3/4" dado.---Jack
Re: Wooden dado plane more build question
>Believe it or not, I did understand your ASCII art there Dean. And Jack confirms what you wrote.
Now, what sort of skew is the blade set at and is it beveled on three sides? (I'm thinking of modifying a blade from a rabbet plane).
I'll assume that its bedded at 45 degrees like a bench plane (but compound with the skew) and around 10 inches long. Are these good assumptions? Not sure about a depth stop at this point, but I'll keep searching for pictures of wooden dado planes to help out.
Jim in Burlington Ont.
Knight toolworks
>Steve has some excellent pictures on his site. There also a style that is not wedged that simply sits into a very small dovetail about 3/16" wide.
That`s what mine look like too.
Bob Hackett(Mainely,Bob)
Re: Wooden dado plane more build question *LINK*
Wolfgang Jordan
>Here are pictures of my dado plane. The construction seems pretty simple, and the blade is not skewed. It's just not necessary, because the bottom of a dado will not be visible.
Wolfgang
Continental dado plane
Derek Cohen (in Perth Australia)
>Hi Jake
This is the nicker for the dovetail plane I recently made. As you can see, it is morticed into the side of the body and lies flush so that the depth stop moves freely above it. The steel was a piece off a ex-3/8" chisel, split at the top (with chamfered inner edges) to slide on a screw. The business end is curved, rather than pointed, so it slices on edge. It works rather well.
>Thanks for detailed pictures, they help a lot. I'm glad to see a model without the skew; it greatly simplifies things for me.
Books that will get you there
>Dunbar`s Restoring,Turning& Using Classic Woodworking Tools(ISBN 0-8069-6670-X) has pics of both the plane and the irons and is just a great reference for putting old tools back to work.
John M. Whelan`s Making Traditional Wooden Planes(ISBN 1-879335-69-7) by Astragal Press will be of more help if you want to build this or a host of other specialized planes.It has in depth drawings and contruction tips.
Mainely,Bob
Dean J in MN
>Don't dismiss the skew. In use I find it isn't there to make the dado smooth, rather it is there to pull the plane against the batten that I have on the board in which I'm cutting the dado.
-Dean
Re: Books that will get you there
>Thanks Bob, those seem like valuable books. Now all I have to do is cost effectively source them on this side of the border (Shipping things from the U.S. can be troublesome).
ThomD
>Here is one with two knives. They self wedge in the slots, which have a bit of dovetail to them. Normally I would imagine this would be a scarry assembly, but the side irons would just be little bits of scrap, and one could take a a few passes at them on the grinder to get the right angles. Also, unlike most japanese planes where projection is critical, it really isn't hyper critical, so a lot of the pressure is off. I think this could be the easiest way, and it does work great.
