Switch block plane?
Switch block plane?
Switch block plane?
Adam Cherubini, NJ
>Does anybody know what a "switch block" is? I'm working on an article. The term is used in an early 18th c tool inventory. The switch block is given the same value as the strike blocks.
TIA,
Adam
P.S. I hope both you and PW like this article. I've spent months researching it. I'm not sure its a great article, but its certainly been fun doing the research.
Re: Switch block plane?
Gary B in Central NY
>Adam,
when is it being published? can't wait to read it.
Gary
Probably used
>to punish the apprentice when he ruined some good wood or took too long on a task! Either that or it was for ambi-dexterous craftsmen (i.e. switch-hitter)! :>)
Shorter Oxford Dictionary definition
Ian in Sydney
>Switch
"a long bunch of hair or coil of hair, esp. of false hair worn by women to suppliment the natural growth of hair" dates from 1878
"to cut off the switches or projecting twigs from; to trim (a tree, hedge, etc)" dates from 1811.
leads me to the supposition that a switch block plane may have been a tool used in broom making
should have looked up "block" as well
Ian in Sydney
>Block
"a piece of wood or other substance on which something is moulded or shaped"
"to support or fit with blocks of wood" dates from 1823
I'll try and look up the full (23 volume) Oxford at work tomorrow
Switches from a willow tree
Andrew F in Australia
>Hi Ian/Adam,
I know switches well - that's what term my parents (depression-era kids) used when I was *really* acting up as a kid - they were green sticks no more than about 1/4" round, about 3' long and very flexible, not to mention painful.
That's one version of a wood-related switch - perhaps used in caning a seat (popular about 1680 in England)??
Cheers,
Andrew
(Whose first thought when reading Adam's description was more a wedge used to change the direction of a force - but why subscribe a switch block a value if this was the case)
I should add
>That seat caning had a resurgence in the late Hepplewhite/Sheraton era - about the early 1800's when the shop that Adam's cataloguing was working.
Just a completely wild (and probably wrong) guess as to the etymology and provenance of a switch block.
Cheers,
Andrew (who's off to work)
Bjenk Ellefsen
>Could it be one of those linguistic confusion ? A link with strijk blok perhaps ?
looked up the complete Oxford Dictionary
Ian in Sydney
>The complete Oxford didn't add much to what's in the Shorter Oxford
However, there was a reference from the 1790s to a "switch" being a form of stop, similar to a 1" deep blind hole
you may have more success with the "block" side of the item's description
the Oxford has several references to "block" used as what I would today call a former, ie the male shape arround which the female part of an item is shaped, or alternatively, "block" being the molding process itself. (most comonly today a "hat block", to "block a hat") but back in the 1800s the useage included forming metal and shaping other materials
so I'm still thinking broom making, seat weaving, etc
