Crazy Idea Implemented - Fast, effective, low cost
Phil Smith
>I have been following with great interest the post below about LV introducing O1 plane irons and the post below about using loose abrasive from water stones to sharpen tools. One of the complaints that you often hear is that the A2 is slow/difficult to sharpen.
The concept of a loose abrasive I think is in fact the most cost effective way to sharpen a wide range of tools if the abrasive is Diamond powder and the substrate is cast iron. Diamond paste and or powder is readily available from a number of sources in a range of sizes the is staggering. The combination of a very soft ruby wheel on a conventional grinder coupled with 1 micron diamond paste I believe is the most ecnomical and fastest way to put a razor edge on a cutting tool. This is particularly true if the edge has a nick or other damage that must be repaired. And if you have moved up to 3V or better tool steel it is the only effective way to sharpen.
Below is a picture of my current sharpening system. It is based on a cheap 8 in grinder with a 46 and 100 grit very soft pink wheels from Radiac. The tool rest are One way. They provide a large stable platform on which to rest the tool which makes hand grinding feasabile. In front of the grinder is a set of cast iron plates that we had a local machine shop make. Three of the plates are in the stroage boxes and the other is shown without the lid. The set includes a series of cast iron plates that are charged with 30, 15, 3 micron diamond paste and the last one I use 1 micron diamond powder. Also shown is a angle guage, and square used to check square that the tool is ground square. The 30 and 15 micron plates are used primarily for flatten the backs of the tool steel plane irons that we are making and are not needed for routine sharpening.
Besides the plates is a series of plane iron that were sharpened with 3 and 1 micron diamond powder. From left to right they are CPM M4 No. 5 plane iron, CPM 3V No. 4 1/2; LN No. 4 1/2 A2; Clifton No. 5 probably O1.
When I am grinding if I grind a straight edge I go directly from the grinder to 1 micron diamond on the plate. If I am not having a good night sometimes I will use the 3 micron paste to remove a grinding error. The one micron is plenty agressive to remove the grinding wheel scratches and yet small enough to leave a polished edge.
