Finally finished my brake
Skip in Falls Church
>It's been an ongoing project since Friday - but I finally finished my brake. Somehow making this thing entailed doing a whole bunch of cleaning and rearranging. We've been working on cleaning and redoing the basement - my wife is dumping some of her stuff to give me more room to store my woodworking stuff, so I ended up cleaning up and reorganizing while I worked on this thing.
Okay, it isn't pretty - but it works. I included my first practice saw back in the picture - it too isn't pretty - but I think I got the method down and won't leave too many hammer marks in the next one. I slipped a blade blank in the back just to see how it worked.
Skip
Re: Finally finished my brake
Another view
Re: Another view
L. Hanson
>Not pretty? Are you kidding?
'Tis a thing of beauty... Great job!
Leif
www.norsewoodsmith.com
Re: Another view
>Thanks Lief - for the compliment and the plans. If you couldn't tell I copied it off the one on your site. (Great site BTW!) I did make a few alterations to fit what I had - but it works. I have blade blanks for a dovetail saw, a couple of pattermaker's saws and a stair saw. You're site's been helpful for all of them. So many saws, so little time. :)
Skip
Some additional info... *MANY PICS*
L. Hanson
>It really does look great, Skip. Since you used the design off of my site - I thought a couple pointers from my experience with mine that may be of some help...
After bending several backs, the bar that acts as a pivot point started bending when starting the second bend - that's the piece of straight bar in this blow-up that has the cut-outs for the hinges:
To review for those that are wondering what I'm talking about, the steps to bend a back with this brake go like this: First, you place a piece of brass the proper size in the brake, then place the entire brake into a machinist's vise (helps to hold it all together, it really isn't strong enough on it's own):
Then bend it over like this to about 90 degrees:
You then re-position the brake in the vise to make the second bend, like this:
Then make the final bend:
It's during this last bend that the pivot bar wanted to bend up after the first 30 or 40 backs - to fix it, I simply add a couple of vise-grips to hold the pivot bar down when starting the bend (there's no brass in the brake in this picture, but I think you can get the point):
I then bend the brass until it hits the vise grips, which is far enough that the problem with the pivot bar bending isn't an issue.
This brake I built quickly, out of store bought stuff. I really only meant to use it on a few saws - but now I've got over 100 backs bent on this one, and it still keeps going:
I've been meaning to make a heavier duty brake, but somehow never find the time. I guess as long as this one keeps working, I probably never will.
Another quick tip - use at least 1/4" bolts to hold on the "handles" (which are just short pieces of angle on mine). I had #10 sized bolts in mine and kept breaking them. Actually, in the first pictures above, I just jammed them into the bolts holding the hinges together.
Finally, I added a few extra screws to each of the hinges (closer to the pin of the hinge) to keep them from bending. I was noticing when bending longer backs the hinges I used (which were salvaged from a door) were bending at that point. Since I added the screws, I haven't had a problem.
HTH
Leif
Very cool, but...
Scott Burr in Ben Lomond CA
>Ya need to work on your welding skills Skip. Just yanking your chain ;^)
Look like it works well.
Re: Some additional info... *MANY PICS*
>Hi Lief,
Since I had to buy everything I used 1/4" machine screws for everything. I also used fewer screws. I'm hoping the larger screws will result in the need for fewer screws. So far I've made 3 bends (I did a couple of more this morning) and it seems to be holding together okay. Unfortunately the flat bar I picked up is 3/16" instead of 1/8" so I couldn't use 2 pieces of flat bar on the one side. I ended up shimming the plates I bent with a thinner piece of brass inserted under it. It seems to work okay.
Of course the thicker flat bar means that I have more hammering to do to finish the back so I may try to get some 1/8" and see how it works. OTOH if I don't do more than a few more backs - I'll probably just leave it as it is.
I ended up short of angle iron too - that resulted in the center handle. I had just enough angle to meet in the middle at a 45 degree angle - so I used some square tubing to make it a center pull. I figured that one more screw in the middle couldn't hurt and I think the square is a bit more comfortable to hold too. All in all it wasn't too hard a project - *after* I realized I needed a new 1/4" drill bit. :) Again, thanks for the help - your plans made it easy.
Skip
Re: Very cool, but...
>Thanks Scott!
I just wish my dad lived a bit closer than 1400 miles away - he could have welded it. :) In spite of the improvisations I had to do, it bends brass.
Skip
ThomD
>Welding, now that is fun. I'm just a newbie where welding is concerned. I TIGed this tab onto the runners of a sled I am building. Coupon done at the same time showed total penetration fusion. Long way to go yet.
