"Backwards" ripping
Paul Kierstead
>or I have this faint memory it might be called the overhand grip? Anyway, I refer to ripping with the teeth facing *away* from you, and the saw almost upright. It is the latter part that I have an inquiry about; I tried this method today mostly because I have a high-ish bench and no horse, and I was too lazy to crawl up on the bench, besides it had to much crap on it.
The difficulty I encountered was the angle of the saw. I am using a rip-filed D12. In pictures I seem to recall seeing, the saw was quite close to upright. Now I could not really get ripping that way; it is hard to estimate the exact angle, but I think the saw had to be about 15 to 30 degrees. It required a little arm extension to keep the toe from banging my legs; probably not as much as I seemed to think it did (paranoia), but still...
Is this a saw filing issue or just business as normal, and I will get used to it?
