Stones for flattening stones.
Marc Broussard in Ma.
>Hi All. I wonder what devices you use to flatten the first cut stone with. I have a 250 grit stone (along with a 1000, 4000, and 8000 for the final sharpening) to establish the bevel angle and it needs to be flattened. With what. A diamond one for $50 at Woodcraft or what do you use and why. Can I get a course/fine stone from the hardware store and use that? I hope the high dollar option is necessary. Marc in Mass who is really getting serious about sharp tools.
Re: Stones for flattening stones.
Jack Guzman from Maine
>Marc,
A cinder block works,so does sandpaper or drywall sanding sheets on a flat surface.I use a diamond plate for my finer stones.---Jack
I use...
Scott Burr in Ben Lomond CA
>Drywall sanding mesh on a flat surface (my TS actually). Finer stones get 220 or so sandpaper but it tends to clog up. I just blow it off of the paper and keep going.
ThomD
>What I don't do is use diamond stones. Diamonds may be forever, but the bond to the base is softer than the slurry from the waterstone, I haven't tried it dry, but wet it wrecks the stones. I keep hearing they have their disbonding problems dealt with and every 5 or 10 years I beleive them and buy a new one only to have the same kid of problems.
All the suggestions so far are good. What you can do is buy two stones in the low range like 1000, use these to rub against each other to keep them flat. They run one of these on the next finer stone and so forth up the line. Works fine. You do it wet.
Also, learn to keep the stones flat. As a starting point look at where they hollow, and don't sharpen there. Obviously the place that hollows is right in the middle, best place, but if you go there it will hollow. Also since one crosses the middle twice for every time one stops at an edge, even moving around will not help completely, you need to concentrate on some of those periferal areas. Jigs make maters worse, they have their purposes, but they tend to overconcentrate activity in certian parts of the stone.
Re: I use...
>Thanks guys. That's what I thought. I didn't think for a moment that the course/very course $50 diamond plate from DMT was the only game in town. Marc in Mass who already had the stuff to flatten just didn't know it.
Smith`s diamond
Bob Hackett(Mainely,Bob)
>After buying and destroying afew expensive monocrystaline diamond stones I went with a Smith`s coarse stone(less than $30 at Lowe`s)and use that on pretty much everything that drywall screen won`t handle including ceramic.
It`s held up very well and I even use it to ease edges of the granite table tops my wife(and her friends)seems to want on all the small tables,window sills and kitchen accessories I`ve been making lately.
It`s like that pink bunny it keeps going+going...
I now flatten all my steel on a piece of blue sanding belt or drywall screen glued to a cast iron surface plate and don`t let it touch the coarse diamond stone.I now know that`s what was killing my high dollar diamond stones.
Mainely,Bob
a bunch of years ago,
Bruce, a MN Galoot
>my chef brother gave me his Norton multi-stone, the big one with 11.5" stones. The stones were badly dished, so I tried a concrete block, sandpaper, and coarse grit on a steel plate, and nothing worked as fast as I wanted. Then I grabbed an old, really crappy, coarse oil stone that my dad once had. The reason it was crappy was that it was so soft it wouldn't stand up to any honing but would just crumble.
That old, crappy stone did a fabulous job of wearing down the Norton stones. It was muuuccccchhhhh faster than any other method I've ever tried.
Bruce
Re: Diamond stone
>Christopher Schwartz mentions using a diamond stone for flattening his water stones, which is probably a viable option. The only advantage I can see to the diamond stone over sandpaper or drywall mesh is the stone would last longer. The main thing I think is to use the whole stone so it doesn't hollow as much, and flatten a very little bit frequently. I "flatten" my stones on sandpaper on 1/2" glass (I just bought drywall mesh) every day I work in the shop before starting my work. I can pretty much know ahead of time if I'm going to be using a plane, and I just flatten the stones till they show even scratches all the way across, and then set them in a container of water until I'm done for the day. I find it less of a mess to flatten them dry, and easier to see when the scratch pattern shows the stone being flat.
Re: I use...
>The only reason I own a diamond plate is because I had to use a 25% off coupon from Rockler on something and I always wondered what those things were really good for.I think I'm probably going to wear it out quick though.I use it for all kinds of stuff.I wish I had a free unlimited supply of those things.They are real handy around the shop.---Jack
Frank
>You can go to the phone book and check out your local granite kichen top guy. He will maybe give you the sink cut outs area for free and then glue a wet & dry sand paper to it to flatten your stones. You can cut it with your Skil saw with a blade from HD for about $9.00. Good Luck
Frank
Alan Turner
>I use a piece of granite offcut from a granite shop (free) with silicon carbide grit (90 grit) wet wth water. When the granite dishes, I get another. My pirmary waterstones are Shaptons, and with this methd I am able to flatten the stones pretty quickly.
So, here's what happened.
>After reading all the related posts about flattening stones I went to my local Ace hardware and bought a course/fine oil stone 2"X8" $14 and used it on my 250 and 1000 grit waterstones and the result was immediate and acceptable. I then used the 1000 to flatten the 4000 and the 8000. Again the results were good. This was not rocket science. Just plain common sense. Marc in Mass who is getting my chisels almost sharp. Still won't pare pine end grain yet. Got a bit to learn.
