Have a question? Ask Woody!
Honing Guides for Stanley 46 Cutters
MarkSmith
>Folks,
What, if any, honing guides do you find to be useful to sharpen cutters for a Stanley 46? I have been finding it difficult to get the skew angle just right. (Slanted one way or the other, resulting in non flat bottom to groove).
Mark
Re: Honing Guides for Stanley 46 Cutters
paul womack
Even if the honing guide does skewed blades, it's still ultra difficult to get the blade into the guide at the correct angle.
To sharpen skewed blades I use a very simple guide (vintage Marples #7418) which can be seen here
blade prep section and Alf has a manual
Since it has a cambered roller, it doesn't control the lateral angle at all, only the bevel angle.
For any skewed blade, I simply note wether there's any error in use, and lean a bit on that side to correct. If you hone frequently, you'll only ever be using fine grits to sharpen, and this approach will keep your blades nicely "on song".
(Also referred to here)
BugBear
Re: Honing Guides for Stanley 46 Cutters *LINK*
Derek Cohen (in Perth Australia)
>Mark
I have used the LV Honing Guide Mk II to grind and hone a number of skew blades, including those for the Stanley #46.
LV will bring out an add-on skew jig for this guide at some time (I do not know when). It will work well (I tested the prototype and can only say that I was impressed), and is worth waiting for.
In the meantime you can make a template for the #46 (and any other skew blade) to use with the LV honing guide. The link for my article is below.
Advances Angles on the LV Honing Guide Mk II
Another approach
Jim Reed @ Tallahassee
>Try this technique with your #46. Grind or hone the blade to the best of your ability, using the original grind as a reference. Do not use the blade slot on the plane for reference. Instead, insert the blade in your plane loose and put the plane on your bench. Adjust the blade until it is perpendicular to the plane's sole and tighten it in that position. Works for me everytime.
Re: Another approach
Mark B Smith
>Jim,
I hadn't thought of that approach. I was pretty focussed on pushing it all the way to the side of the cutter bed (probably not correct terminology).
I'll give it a shot.
Mark
Re: Another approach (or , Setting up the #46)
>Hi Jim
I pay attention to you, especially in regard to the #46, since I respect your knowledge. But I must question this approach. As I understand, it is important to line up the edge of the plane's slitter with the edge of the blade. This should be easier to do, and to replicate, if one has a single reference point to aim for. The reference point is the sidewall of the plane. If the bevel is honed at the correct angle (that places it perpendicular to the plane's sole), then set up should be just a matter of pushing the blade into position and tightening it down. To do this I place a small (tiny) steel square (used as a straight edge) against the outer body of the plane. It is then a simple matter to achieve this alignment by pushing the blade up against it. The importance of this is reinforced when one wants to adjust the blade projection. Again, with the straight edge in place, loosen the clamp and adjust the projection by sliding the blade up/down the straight edge.
Bottom line - the angle at which you grind and hone the bevel is important.
What do you think?
