Cock beading ?
Cock beading ?
Cock beading ?
Bjenk Ellefsen
>I have read bits of information here and there about this for drawers and such. It doesnt look very difficult to do in the case of drawers but lately, I have seen cock beading on the lower edge of a lowboy. That could'nt have been easy.
I wonder if there are better sources of information on how to do that ?
Re: Cock beading ?
Re: Cock beading ? *LINK*
Adam Cherubini
>Its a seperate piece of wood, nailed in place. The question I had was how it was done. It was bent, not sawn. So was a form made and the pieces steam bent? The case could then be sawn to the bent pieces. I tried this and it didn't work. The pieces changed shape as they were mitered and it was a total mess. This also failed the sniff test. Jigs and fixtures don't seem to fit with early cabinetshops.
On my next attempt I scrolled the case, then bent the hot wet pieces to it. Again, not learning my lesson, I tried a caul to hold the beads while the glue set. Didn't work. There were tons of gaps under the beads. No amount of caul refinement seemed to work.
So I slathered the case with hide glue, and nailed the hot wet pieces in place splitting them just like the originals. I thought the splits were caused by 300 years of seasonal movement, but now I think otherwise. A few strategically placed pilot holes helped reduce the splits on the next piece.
The nails were flat heads or were filed flush on the originals. I left mine proud because I'm a hack.
Adam
cock beading
Re: Cock beading ?
Re: Cock beading ?
Bjenk Ellefsen
>Adam, thanks for this very insightful account. You confirmed my fear that this kind of decoration is no small feat. I would never have guessed that nailing was the way to go.
Re: Cock beading ?
No question
Adam Cherubini
>This seems like the sort of thing that may have been done in the solid, but I've yet to see an example of that. I wouldn't be surprised to see sawn out cockbeads however.
Adam
Re: Cock beading ?
Re: No question
Bjenk Ellefsen
>Oh, by the way, can I tell you how that William and Mary lowboy reproduction is stunning ? The finish looks like milk paint.
Re: Cock beading ?
Are you sure
Neal (San Jose)
>Are you sure it is cock beading? I have a wonderful 200 year old
china cabinet, and what looks like cock beading, on closer inspection turns out to have been done with a scratch stock. Or, maybe carved. Anyway, I am making a piece (wine cabinet) that I'm using the scratch stock approach, and it seems like it will be a lot easier.
Re: Cock beading ?
Re: Are you sure
Alan Turner
>I am probably wrong, but I thought that a bead cut in with a scratch stock was called a quirk bead, and it differs from a cockbead in that it is not applied, but is part of the piece, and because it does not sit ablove the plane of the drawser, apron, etc.
