ADVERTISE HERE - FREE TRIAL
Weekend Projects
Weekend Projects
Weekend Projects
ydb1md
>After constructing a couple of projects using mortise & tenon joints with drawboring,
and not being able to afford (justify) the expense of antique drawbore pins, I decided to make my own.
I did learn that I could drawbore without the pin but I destroyed a few oak dowels where a drawbore pin
would have told me to modify my joint a little. Following tips from Christopher Schwarz, I went to my sears store and picked up their punch and alignment
set 94285. The alignment pin that I used had a beginning diameter of 5/32" and is 7" long. I
ground the flat,blunt tip on my grinder to better mimic the profile of classic drawbore pins.
I used alcohol to clean off the machine oil and a "rust eraser" to take off the black oxide finish.
The handle is made of some maple scrap that I had lying around. The hole in the handle begain as 3/8" which
I enlarged to allow the pin to fit. The pin required a 7/16" hole but I only had a 3/8" and 1/2" to choose from.
So, not wanting to go oversize, I used the 3/8" bit and wiggled the workpiece to enlarge the hole. I could have
heated the pin red hot and plunged it into the wood but I decided not to go pyro and burn myself or my bench/shop.
I used some 60 minute epoxy to secure the pin in the handle. The handle is roughly oval in shape. I knocked off
the corners with the bandsaw and finished up with a rasp, card scraper and sandpaper. The finish is 1 coat of BLO
and 2 coats of wipe-on poly.
This weekend I also made a chisel hammer. It's sort of a blend of both of Glen Drake's
chisel hammers. I used some 1-1/8" brass rod to make the head. One end is slightly domed, the other is flat. Once again,
the handle is maple with a BLO / wipe-on poly finish.
Re: Weekend Projects
Weekend Projects pics
ydb1md
How did the new drawbore pin work?
Pam Niedermayer - Austin, TX
Re: How did the new drawbore pin work?
ydb1md
>I just wrapped up the pin this evening. I'll probably try it out next weekend
Frank D. in Montreal
>Nice work! It's always very satisfying to make your own tools, and the pleasure comes back each time you use them.
If epoxy suits you that's fine, but you should give the burning in method a go, there's not much risk of fire (just a little smoke), and it's a lot quicker than mixing epoxy and cleaning up the squeeze out. You'll soon find yourself sticking handles on everything, it's so easy. Just a thought.
ydb1md
>As soon as I get a lathe to make my handles, I'll be a really happy man. =)
Nice work!
Scott Burr in Ben Lomond CA
>I realy like the hammer. How did you round the brass? Attack it with a file?
Nice lookind DB pins too!
Jim in Burlington Ont.
>I've looked at buying one of those hammers and I like your idea alot better. Where did you get the brass from. I looked at a few metal places and no places will sell small amounts of big brass rod.
brass rod
ydb1md
>Hi Jim,
I purchased mine on eBay. But, I've also seen some places online that would sell you short pieces for reasonable prices. I'll dig around through my links and see if I can remember where I found the best prices.
Dave
Re: Nice work!
ydb1md
>Hi Scott,
I tried a file and that was too slow. Then, I tried my slow speed grinder. That was slow and it gummed up the grinding wheel. Finally, I came up with a jig to hold my belt sander upside down. That was perfect. I later modified the jig to hold the belt sander vertically and I built a tilting platform for my work so I could use it like bench mounted belt sander. I can sand wood or grind a camber on my plane irons.
Re: Nice work!
ydb1md
>Hi Scott,
I tried a file and that was too slow. Tried my bench grinder and that was slow -- and it gummed up my grinding wheel. Then, I made up a jig to hold my belt sander upside down. That did the trick. After trying that, I modified the jig to hold the sander vertically (like a bench mounted one for sharpening, etc) and built a tiltable work support so that I can sand wood, grind metal or put a radius on my plane irons.
sander jig 1
ydb1md
>I removed the work support for clarity.
sander jig 2
ydb1md
sander jig 3
ydb1md
Re: Weekend Projects *LINK*
Bob Fawcett
>I've bought brass rod here. They carry up to 1 1/2" diameter.
Jantz supply
Re: Thank you for the pics.
ydb1md
>You're welcome Scott. Let us know how it comes out.
Dave
