LN Shoulder Vises
LN Shoulder Vises
LN Shoulder Vises
Stephen Wilson
>Has anyone fitted either the Chain Drive or Quick Release shoulder Vises from Lie-Neilsen? Any info or opinion on quality, ease of fitting, performance in use, etc. much appreciated.
Re: LN Shoulder Vises
Matthew Dworman
>I haven't fitted either, but I had the opportunity to check out the quick release vise at their shop this summer. It is very well built and operates smoothly. It is very impressive. You should know that they do not make it - it is imported from germany and is the same one that woodcraft sells, but LN's price is better... FWIW
Matthew
ThomD
>I have the tail chain vise. It is a good unit. it has a few bugs, but it seems very popular with pros. One thing i didn't like about it, in a non-serious way, is that it had this plastic cover for the chain drive, then they came out with an upgrade to metal. I put it on my new bench with a double row of dogs. This means that I can hold work equaly well from either side of the bench for pull or push planing, or apply pressure over a wide range. I comes with the usal Lee Valley overkill instructions. They are like 30 pages. And you have to read them because there are some bad things that can happen. I'm used to executive sumaries so this stuf drives me crazy.
The cool part about the chain system is how good it is for different systems like it can be used for face vises or leg vise, basically anything you want to dream up.
I haven't even seen the quick adjust vise. QA is a great feature though I don't like the mechanicalness of a lot of tail vises. I can live witht he metal as witht he chain drive, but I don't like it ti clank around. If I build another I will try to do a big screw for it.
Didn't TLN say that he wanted to produce his own?
RichStevens
>Guys,
I recall reading the transcript of TLN's online chat here at WoodCentral that he wasn't happy with the quality of vise components he was receiving from the present German supplier.
Seems he was contemplating making his own with much tighter tolerences and better finish.
Shoot me if you will, but judging from images I've seen of these vices, they look rather 'rough' by LN standards. Anyone that can produce a vice with close to zero backlash and superior casting/machining will get my order - I've been in the market for a quality tail vice for close to 10 years and I'm still waiting.
I am happy to wait, considering my ultimate workbench will be built out of some very old and heavy Tasmanian Blackwood and Tasmanian Myrtle. Sorry, didn't mean to gloat...
Rgds
Rich
Melbourne, Oz
Joe Rogers, Northern Virginia
>Yeah Rich...as if I believe that. :-)JR
Now that Blackwood.....
Bob Wilkerson - Richmond, VA
>sure would make a beautiful bench! I picked up a coffee table in Tas made from it in the early 90's and brought it home as luggage..... Too bad the ex now has it. A friend there had a living room paneled completely with it at his house in Devonport that was exquisite.
Bob
Alan Turner
>I have not seen the LN quick action shoulder vises; only the photos on the LN web site. From these pix, it appearrs that the gravity drop half nut mechanism is the same as the old Richards Wilcox QA vises. I have several of them, and they work quite well. I also have an older QA that has a groove down the middle of the lead screw, and it works well also, but limits you to one turn after pushing the front jaw tight to the stock. My preference is for the gravity drop hald nut. These older Richards Wilcox vises are getting very had to source. The ones that I found came from pattern shops, and were probably the inexpensive alternative to Emmerts.
