Re: Inamoto-san seminar
ThomD
>The more I think about it the more it was a rich experience. The best part is working with other people who all know something I don't know and was graterful to learn. Up here I have never met another woodworker who uses Japanese tools. Obviously there are others, and there is a big japanese comunity, but so far they haven't fallen across my path.
I used single blade planes with loose fit and they worked fine but they don't handle as well as the ones I now make.
I think your method may well work just fine. I have dais kicking around fromt the late 70s that I pulled a blade out of to use in something else. Putting the blade back in they work fine. Of course if you left a particular blade in a dai for 20 years it might need tuning also, so whether it will be any worse without the blade remains to be seen. I only have one dai that is unuseable it was for a jointer and it bent like a banana. Just something about that piece of wood, one I bought too.
I'm just getting worked up to make my 4" beam plane. It is going to be a pretty rough prototype until I feel it is worth formalizing.
I am also on the trail of some exceptional iron I hope to be able to forge into some laminated blades. It will all take years to sort out, but it is gradually moving in the right direction.
Are you still using the dai supplier in Cali? I still have a few blades to fit.
