Schwarz holdfast
Schwarz holdfast
Schwarz holdfast
ThomD
>I made this up yesterday. First time I have tried anything like this. Used a pretty ugly piece of steel, and it still has some scale on it. I wish I had picked a better piece because the result works perfectly. I based it on Chris' article in Woodworking magazine. I also made a Schwatz style drawbore pin so that magazine was worth what I paid for it!
Re: Schwarz holdfast
Christopher Schwarz
>Thom,
Nice looking holdfast. The shepherd crook's shape is especially useful for mortising. I should also post a photo of the low-profile one that Don Weber made for me -- we dug up a photo from Goodman and modified it a bit based on an early original I picked up on eBay. It's tremendous for planing because you don't hit it.
I'll try to do that early next week. Thanks for the photo!
Chris
Don't worry about the scale...
Joe Rogers, Northern Virginia
>It probably aids in setting the holdfast. I theorize that the surface of the rod is important and a too smooth rod is prone to slipping or requires heavy impacts to set.JR
Re: That lady propane
ThomD
>Thanks, I would love to see that. It started out a lot lower profile because the susccessfull version in the original article, pre Tools For Woodworking, where flat, and I thought that might be a point in getting more flexibility out of the holdown. I pretty much nailed that shape right out of the gates. I measured the pad at 83 degrees pretty dead on. Then I figured why not curve the pad a little, and that subtle change forced me to go way high up in order to get the position back to 83 degrees.
I thought the 83 degrees might not work on the thicker topped benches, but it seems fine. Nice thing about a gas forge is one can just tweak the angle at will like cooking a hotdog on the grill, Hank Hill would be proud of me.
Re: Don't worry about the scale...
ThomD
>Mill scale is dirty, though it can just be washed, and I agree about grip. I like it to look a little primative. Just a little tunning will be required. Also the more black the less red as far as oxydation is concerned.
