Roubo Work Bench Update *LINK*
les winter
>Well, with a bit of help from you, my Roubo bench is coming together.
It's 30" deep and a bit more than 8 feet long. Unfortunately, I cut the front apron incorrectly and need to extend the right side of the top to accomodate a tail vise.
I'll have more later
regards
Les
http://www.joanwinter.com/pages/9/index.htm
Re: Roubo Work Bench Update *LINK*
Where are you hiding the side rails?
John Clifford in Chicago
>Nice bench but I'm confused as to where the side rails are. Are they coming next, or are you not using them? If you are not going to use rails on the side have you seen this done elsewhere? The reason I ask is that I don't recall seeing a bench without them. I think you'd loose a lot of stability and it might be prone to racking front to back. Just curious. John.
Re: Where are you hiding the side rails?
les winter
>Good eye, John.
I will be installing a substantial shelf inside the long stretchers; the ledger strips are in there already. The shelf will be 1" southern yellow pine, which is stiff and substantial. The boards will run front to back, so the expansion/contraction will be side to side. I think that should do it.
You may be interested in why I left off the side stretchers. I built this thing a little bit differently than was published in Woodworking Magazine. Specifically, I glued up the center of the top, leaving off the front and back 6 inches. These I glued up seperately and then installed the legs and long stretchers. Finally, I glued these two assemblies, one at a time, to the center section. Then I kicked out the sawhorses that the thing rested on and took the pictures you just looked at.
By following this proceedure I was able to drill the mortises on my drill press, and, more importantly, I didn't have to build this monster on its back and then try to turn it over on its legs. It was built right side up.
Using front to back stretchers with this assembly technique looked a bit difficult to me, so I left them out.
Even without front to back connections, the thing stands very fine.
Thanks for looking,
Les
