Mostly for Bugbear and Alf
Bill Houghton, Sebastopol, CA, gettin' soggy
>I missed acquiring a Record 076 on eBay today by half a pound - lost courage, partly because the shipping was going to run GBP6.00 or so, not far off the bid price, and so didn't put in a maximum bid above the 11-1/2 pounds I was bidding.
I have the impression that Record stopped making the 076 early enough that these are decent tools, compared, say, to a late Stanley 90J - is that a correct belief? Can I expect an 076 to be a decent, if primitive, tool? Certainly, the one I missed seemed to have plenty of bearing surface for the iron, compared to the threads of support you find in, say, a dread Stanley 75.
Re: Mostly for Bugbear and Alf
paul womack
A Record #76 is "OK", but I'd far rather have a #77 with the adjustments.
I actually have both (the #76 came first) but I don't remember ever using the #76. In truth I don't use the #77 very often either.
Despite having a REALLY cool name, a bullnose shoulder plane is not that helpful.
BugBear
Alice Frampton, UK
>Luckily BB saved me having to confess to never having so much as seen a #76. Except I just did anyway... But I'd agree, the bullnose Preston I have (forerunner of the non-adjustable Record #77) doesn't get used much either.
Cheers, Alf
It's alot better than a...
Scott Burr in Ben Lomond CA
>Stanley #75 Bill, that's one thing for sure. But then again what's not. That said I agree with Paul and Alice about the 077 being a better plane, especially the 077a with it's adjustable (by shims) mouth.
The quality is somewhat better than a Stanley 90J (english made).
Good luck with your search...
Thanks
Bill Houghton, sunny, but ya can't trust the sky
>I think I need a better bullnose at the moment for a project (now in winter limbo) cleaning out the rabbets in the window opening on a screen door, into which I plan to put replaceable screen/storm window units. I used that filled epoxy that's graded as a wood putty, and once it sets up, it's hard stuff. The rabbets are a bit too short for my No. 78, and the doughty if crappy little No. 75 just isn't getting it. I'm leaning toward a screaming whirly thing, just to get it done, once I get back to the project come Spring.
No idea how much I'd use it after that - certainly the No. 75 hasn't seen a lot of use.
I use my Preston quite often
Dave Thompson - Champaign IL
>I have a few Preston bull noses (1355, 1355A, 1347NP), all of which I paid the trans-atlantic shipping for from the UK. 9GBP is cheap compared to what I paid for my last two Records. They are beautiful little planes (LN's of the 19th century), and I might admit to a collecting tendency in this case overruling pragmatic use purchase reason. However, I actually use the less common 1355A quite often. It performs very well... a little better than my 1355 which is the 1 1/8" version. They both look like a fancy version of the Record 076 and are the predecessors to it. I can't comment directly on the Record as I haven't used it.
Ofcourse, I'm not sure why you're asking... I would take advantage of any miniscule reason to buy a specialty plane.... ;-)
enjoy,
Dave
Re: It's alot better than a...
paul womack
"Let's be careful out there"
Record started with a non-adjustable #77. Then introduced the adjustable nose, and called this variant the #77a.
Then they stopped making the non-adjustable version.
And THEN they called the adjustable version the #77.
So...
While a #77a is ALWAYS adjustable, a #77 is sometimes adjustable.
Take care on Ebay - look at the nose of the plane; the adjustable one has a screw in the middle, which is you undo to remove the nose.
BugBear
