Plane Irons-Quick Touch-ups
Tom Higgins
>I am a little confused. I have seen David Charlesworth's videos, and read Ian Kirby's sharpening book. My question is basically how do you quickly rehone a blade when you are in the middle of a project? I personally have tried the waterstone routine advocated by both of the authors. Granted, they have much more sharpening experience than I do, but dragging out the stones, preparing them, using them, and cleaning up the mess is not, at least to me, very quick.I can certainly see a place for something like a Lap-sharp or the Veritas sharpening machine.They seem a lot quicker.What methods do you use? Thanks.
Re: Plane Irons-Quick Touch-ups
paul womack
I though both authors recommended dedicated (mucky!) sharpening stations.
BugBear
Dean J in MN
>In my shop my stones are always ready to go, I use waterstones so that just means I have them sitting in a tub of water. If you use oilstones even eaiser, they are always ready after a squirt of lube. I have an area to sharpen in so it is just a matter of taking the iron over and honing the blade. It is a pretty simple task to keep a waterstone flat if you don't let it get out of flat. In the process of flattening a blades back you need to keep up with the stone hollowing, but this is a task I tend to do in groups, flattening as many backs as I can stand to do. Once you are working on a project you are no longer in that stage, and your stones are flat. Honing doesn't wear them very fast, so a quick pass of your prefered flattening method is all it takes.
It takes me just a few moments to walk over, hone the blade, and get back to work. I avoid honing guides, which also speeds up the process, but I'm not religious about them, if you use them fine, but it is a matter of time before you need to learn freehand honing. Gouges, fore plane blades and the like just don't work well in a guide.
In my opnion a machine isn't going to save you time honing a blade. Rough shaping of the bevel, yes, honing, no.
-Dean
Dan Donaldson
>I just set up the stone when I start and clean up when I am done. It only takes a couple of minutes to wet the stone (I generally am only using the finest stone while working) and I don't put anything away until I am done. I keep a spray bottle handy to rewet the stone as needed.
spritz the stone, take a couple of passes, hit the hone and done, back to work.
What I do
Ron in Kokomo
>Or used to do when I actually had time and a ship was to keep a strop on my bench charged with the magic green dust and would periodically slip the iron out of the smoother and make a few passes over the strop. Worked wonders
Ed Mulligan, Cape Cod
>I have spare irons for my commonly used hand planes. Instead of sharpening, I swap in a new iron. If a bench chisel needs sharpening I'll grab a sharp(er) chisel. When no spares remain I touch up with green compound on an mdf block until a major sharpening session is needed. I recall an old photo of Ian Kirby in a sharpening session with a dozen or more plane irons which is where I got the idea.
For carving chisels I touch up with a leather strop charged with green compound.
Ed
ditto, and...
john jesseph
>I use strops and green compound- leather for the bevel, hard maple for the back...
A different approach
Jim Reed @ Tallahassee
>Changing or sharpening blades is too time consuming when I am in the middle of a project. To avoid it, I first replaced most of the factory blades in my user planes with my own which are harder and require less frequent sharpening. I also keep a wide range of planes on hand along with some extras. If the #5 goes dull, get the other. Or get a #5 1/2, #6 or even a #4. Some planes also seem to work better on some boards (???). I say the problem is that you are probably trying to get by without enough planes on hand. 8-)
Diamond media, plus hollow grind
Wiley Horne--Glendora, CA
>I use 3 micron and 1/4 micron diamond paste on metal plates. The plates are kept in a drawer near the bench. It's quick and easy to use, so plane blades and chisels never really get dull. About every 10 or 12 resharps, go back and hollow grind. Wipe off the 3 micron before going to the 1/4 micron. The hollow grind removes the temptation to keep putting new and steeper facets on the bevel, plus it makes everything very fast.
I also keep a 12000 Shapton and a coupla very high grit natural water stones on the bench, along with a spray bottle of water.
And a strop with 1/2-micron green from Hand American, especially for gouges.
Wiley
I use a strop...
Scott Burr in Ben Lomond CA
>Gerrn compound on a masionite board for chisles a few swipes freehand does wonders as you going along. As other have said it easy for me to grab another plane and contiune on (I keep 2 No. 5's on hand, and have a small bevy of smoothers). For sharpening plane irons "on the go" nuthin' beats a quick scary sharp session.
I use a strop...
>Green compound on a masionite board for chisles a few swipes freehand does wonders as you going along. As other have said it easy for me to grab another plane and contiune on (I keep 2 No. 5's on hand, and have a small bevy of smoothers). For sharpening plane irons "on the go" nuthin' beats a quick scary sharp session.
Jim in Burlington Ont.
>I often just pick up another sharp plane and keep going. If it's a special plane and needs a little touch up nothing quicker than 0.5 micron paper on my granite reference stone.
Ditto
Hank Knight from SC
>I keep a Norton 8000 stone next to my bench with a spray bottle. No need to pre-soak an 8000 stone; just spritz it and you're off and running. I usually take a minute to flatten the 8000 when I finish work so it's ready for the next session. Unless I've given it a real workout, it only takes a few swipes on the flattening plate to get it back to pristine condition.
Alan Bierbaum, near Denver, CO
>I use the film from Lee Valley in 5 micron and 0.5 micron grits. A couple of corian backsplash offcuts with a piece of film on each side (front and back) about 3" x10". Handy and quick for touch up use.
Alan
Phil Smith
>Iuse 1 micron diamond on cast iron plate. On a good night I can go from the grinder with a soft 100 grit pink wheel directly to the 1 micron plate.
STROPPING WORKS!
HC Sakman
mikew
>Hi Tom,
As many of the others, I keep a stone on my bench while working. A 2000 grit in my case. Though I also recommend having more than one plane for the task at hand.
Kinda hard at this point as I've sold off most duplicates. It forces me to sharpen more than I was use to. But it is quick. A couple swipes and back to work. I especially hone my chiles frequently while working.
Take care, Mike
