Tuning chisels
Tuning chisels
Tuning chisels
Steven Roxberg
>The most recent Popular Woodworking issue or their Hand Tool issues talks about tuning chisels.
I get the chopping cut, because I mainly use my chisels for cleaning up test dovetails ( I still stink at them ).
They descibe a long handled chisel as being used for a paring cut. Can someone describe this cut and when and where it might be applied?
As always your help oh great wise ones (no pun intended, and I didn't use the old adjective), is always appreciated.
Re: Tuning chisels
Re: Tuning chisels and paring cuts
Bob Hackett(Mainely,Bob)
>When you say a paring cut then I think bench chisels and flat work.Now if you say planing cut then I think turning.
A planing cut can be taken with either a skew or a spindle gouge.I can explain either approach but it is something best learned live and at the lathe.
A paring cut is just a cut taken holding the back of the chisel parrallel to the surface being cut and is usually a fine cut used for things like final fitting of a joint.
Hope this helps.
Mainely,Bob
Re: Tuning chisels
Re: Tuning chisels
Dan Donaldson
>A paring cut is when you use the chisel by hand (pushing it, not striking) and basically slice off the wood. Many cut out the waste in a dovetail with a coping saw, leaving just a little from the line, then slice to the line with hand pressure, possibly using some kind of a fixture to stay square.
Re: Tuning chisels
a link
Ron in Kokomo
>http://www.taunton.com/FWN/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2054
Re: Tuning chisels
Jim in Burlington Ont.
Long handle
>I've never found a use for them. If I'm paring anything my hand is holding the steel within a inch of the edge for maxiumum control.
Re: Tuning chisels
Re: Long handle
Warren in Lancaster, PA
>Paring is done with two hands on the chisel. Usually the right hand is on the handle and the left on the steel. A paring cut takes a thin shaving off the wood like a plane without the body; there is a very shallow angle of attack. This angle is critical- too steep and the chisel is too hard to push and too shallow and the chisel slips out and stops cutting. A longer handle makes it easier to control this angle. Paring can be done with the grain, sideways or diagonally across the grain, or on end grain.
You can pare with any chisel although you will notice if it is not sharp. Chisels made for just paring are rather long with somewhat thin blades.
