help darkening maple
frank shic (walnut ck, ca)
>anyone know what stain or dye to use to darken a virtually WHITE piece of maple so that it has the pinkish hue of regular maple? i'm in the home stretch of completing my kitchen cabinets but i had nothing left but white maple to make the false lights. if worst comes to worst, i'll just leave them as they are since i really would like to finish these doors within the next couple of days. i will NEVER do glass cabinet doors again!!!
Re: help darkening maple
Patrick Gibbons, Houston, Tx
>I'm not sure if you're trying to match wood or if you're working with all new wood. If matching is not a problem, then one solution is to use garnet or buttonlac shellac. I did this on some maple and am very pleased with the results. It is now seven months after finishing the project and the shellac finish keeps mellowing and improving. Otherwise, get some pigments or tints that are compatible with your selected finish and experiment on scrap until you have the desired hue. I read an article recently (?) that advised combining tinting with staining for a great look. Never tried it, but maybe someone else has.
Couple ways to go
>This is a tricky matchup job, Frank, but there are a couple ways you can experiment with. One is to simply tone the finish on that white maple door. Add a couple drops of dye to the finish itself until you have whatever cast you need to match the other doors. The other way is to make a v-e-r-y dilute dye solution (either alcohol or water soluble, whichever you prefer) and wipe on a wash coat of it prior to finishing.
Of course, there is a hidden variable here: The maple is likely to change color with time, less with a lacquer finish than with an oil or varnish, but noticeably nonetheless. It will be hard to predict whether a good match today will still look right in a couple years.
Slippery slope.
Re: Couple ways to go
>thanks ellis! i'm thinking about just leaving it as it is. right now, the white maple forms the muntins on the doors so perhaps they'll form a natural HIGHLIGHT. of course, the next time i do another kitchen (hopefully a LONG TIME) i'll be more careful about color and grain matching meaning that i will NOT be purchasing ANY of it from home depot which got me into this mess in the first place!
ThomD
>First rule of buying wood at HD, only cherry pick! One can get amazing wood there by culling but if one has a set minimum one needs for a particular project...
>will keep that in mind although i doubt i'll be purchasing lumber there again since discovering the local lumberyard is closer to me and actually helps LOAD the wood for me! yup, i was pretty STUPID to buy over 100 board feet at home cheapo without paying attention to the color or grain... live and learn... :)
white and "normal" pink
bill tindall
>I am puzzled by this white and pink comparison. Hard maple sapwood is white on a fresh surface and it ages to a honey color in light. The heartwood is various colors, usually grey. But I have yet to see something pink in hard maple. In any case it is hard to tell what shade these things will wind up in 10 years as they oxidize and bleach in the light. My bet is that this "pink" is going to bleach away and both will darken and wind up similar, presuming they are both hard maple and one is not birch or beach which can be pink.
SOLUTION
>thanks for all the input guys. in the end, i scrapped the muntins that i had previously glued into the door. i had struggled with trying to rout them so that i could get a thin strip down the middle but wound up getting a tiny sliver which easily broke off with moderate pressure but after gluing them up i realized that the edges of the muntins where the meet the central vertical one were blatantly obvious. that plus the color equalled a trip down to piedmont lumber and another $50 exchanged for another piece of maple of the proper color.
the ironic part is that i had thought using muntins would save money on the amount of wood i'd have to purchase, but i've eaten up most of the savings with all the MISTAKES i've made!
this afternoon will be round 3....
