Hand tools to the rescue!
Stephen Kirk in Quakertown, PA
>I just have to post this, since it seems I'm being steadily forced onto the handtool path. I'm building a new bench, and I was ready to rout out the pocket for the face vice to sit in. I set up the router, checked my max plunge depth, marked out the waste area, put on my dust mask, put on ear protection, plugged the tool in, flipped the switch, and ... nothing. 1/2 hour of putzing with the router to try and clean out the switch and I may have broken in further.
So, I figure, I'm starting to use hand tools more, so lets see what I can do. I have a little Craftsman dovetail saw, and a set of Craftsman chisels that I put a good edge on. I was able to make several cuts along the edge of the bench to outline the notch, and then just started tapping chunks out with the chisel. Took about 45 minutes, but if I knew what I was doing, probably would have been 10 minutes or so.
Now to resharpen, since the laminated MDF probably dulled up the chisels pretty good. Just thought you all might like another hand tool rescue story.
