Half Blind Pins - EDM *LINK*
Lon
>Ran across the post on removing 1/2 blind pins on 45's. If you are into tech and don't want to ruin the wood, here is an alternative approach. http://www.joemars.com.tw/e/p7.htm
Wire EDM
Lon
Wire EDM
All these technical terms
Bill Houghton, Sebastopol, CA, gettin' soggy
>I like the "non-nertical machining." Guess I should have paid more attention in shop class, and I might understand some of the terminology better.
Can't say it be good...
Scott Burr in rainy Ben Lomond,CA
>EDM is a process using a charged wire to destory metal, i.e. etching so to speak.
It's commonaly used to make plastic molds today. You would have to charge the plane with a pos charge to start to get a reaction. By the time you got the beast working and applying enough rod to burn the pin out your handle would be on fire and peeling the plating off your plane.
There's got to be a better way...
