Block Plane ID
Block Plane ID
Block Plane ID
Thad Smith
>Once again I need some help. I am trying to figure out the provenance of a block plane I bought recently. It looks like a 601/2 with an adjustable throat but the adjuster is not like any I have seen before. What really caught my eye was the stamp on the blade. It is a L. Bailey blade with a patent date of Aug 6.67. It has a knuckle lever cap and in the bed is cast Made in USA under the blade adjuster. I have not been able to find any plane similar to it. I have included some pics.
Thanks
Thad Smith
Re: Block Plane ID
Re: Block Plane ID, 2nd pic
Thad Smith
>Second pic of blade
Thad Smith
Re: Block Plane ID
Sargent Frankinplane
Todd Hughes
>Your plane was made by Sargent, looks like be a no. 5607 which was made from 1920's to the 50s. During the war they had the black nitrate finish which yours looks like. Alot that you see are Craftsmen ones made by Sargent for Sears , with out the correct blade can be hard to tell if it was a Craftsman plane.
The blade is from an older stanley Block plane, probably a 9 1/2. They used this blade marking from 1879 to about 1890 ....both pretty common though first time I have seen them together....
Maybe somewhere a guy has an older Stanley 9 1/2 wondering why he can't find any other Sargent plane that looks quite like it, eh?.....Todd
Re: Block Plane ID
Re: Block Plane ID
Kurt Loup, Baton Rouge
>Here's a picture of my Craftsman version.
Kurt
Re: Block Plane ID
Re: Sargent Frankinplane
Thad Smith
>Todd,
Thanks for the ID. I was wondering if that might be the case as I know the older tools would not have Made in USA cast in the bed. I was looking at Millers Fall and Stanley planes trying to find a match. It never crossed my mind to check Sargent. Since the plane and blade are common I will turn it into a user. Thanks again for your help.
Thad Smith
Re: Block Plane ID
Re: Block Plane ID
Thad Smith
>Kurt,
That looks to be an almost perfect match. The only difference I see is the blade adjustment knob on mine has a swirled pattern on the end. Thanks for the help.
Thad Smith
Re: Block Plane ID
Re: iron
>The iron with the L Bailey's stamp on it is not really all that common in tool hell here. If you want a good user plane, I would tune up that plane and put a Hock iron in it.
