Removing Frozen saw nuts?
Christopher Fitch@Memphis
>Ok how do I do it?
I have a Disston saw that I'm trying to clean and one of the sawnuts will not loosen. It just spins in the hole when I try to unscrew it.
So what's the secret?
>Ok how do I do it?
Re: OLDTOOLS expertise *LINK*
paul womack
http://nika.frontier.iarc.uaf.edu/~cswingle/archiv
I should have phrased my issue better
>There is one screw that is stuck in the nut. When I attempt to unscrew the screw, the nut spins with the screw. I have already tried tapping with a mallet but it has not helped and I tried a rubber gripper thing and the nut still spins with the screw.
Thanks for the link Paul; I'll check it again but I'm not sure if any of the comments apply to my situation.
Re: more OLDTOOLS wisdom
paul womack
Short version: epoxy a hex nut on, undo with spanner (careful!), use heat to remove epoxy.
BugBear
The Cause....
Bryan in Broad Ripple, IN
>Initially, I belived that corrosion or general gunk caused this condition. However, what I have found is that 99% of the time, the threaded portion of the saw nut is too long and bottoms out prematurely, before the wood can grab the nibs on the sides of the nut. The result: the nut spins, and strips out the wood, which worsens the problem.
If you shorten the threaded portion of the niut assembly by about 3/32", the nut will grab, and will not spin when it is re-inserted.
-Bryan
Re: Removing Frozen saw nuts?
Wayne Anderson
>Usually, if you just put some good sticky tape across the nut or medallion it will stay put enough to do the trick. Make sure the tape sticks well to the nut *and* the wood handle, and hold your thumb tight on it. The nut is made like a carraige bolt, with a somewhat square shaft to keep it from spinning, but it must have spun out. -Wayne
Re: Removing Frozen saw nuts? - Followup
>I tried the rubber gripper. That failed...
I tried Wayne's idea of sticky tape. No dice...though it did remove some tarnish from the brass and some finish that was flaking off the handle (oops).
I then tried the coarse sandpaper on the bench and impact driver idea from Paul's second link. That worked but it did leave nice circular scratches on the face. So I pulled out the Abralon/ROS and polished it up and now it's all shiny new and looks different from the rest. Oh well at least it's off...
thanks for the suggestions.
